Author: Subject: Sierra cosworth front disks
shortie
posted on 4/2/04 at 04:55 PM Reply With Quote
Does anyone know if Sierra Cosworth front disks are the same as standard disks?
thanks,
Rich.
ady8077
posted on 4/2/04 at 05:29 PM Reply With Quote
Hi Rich
Cosworth disk are bigger
Acording to my Burtons cat
standard sierra 240mm
XR4x4 260mm
2wd cossy 283mm
4wd cossy 278mm
Hope this helps
Adrian
MarkL
posted on 4/2/04 at 11:03 PM Reply With Quote
You can get a calliper extension from dax cars for about £25 it fits the standard sierra hub.
It enables you to use the standard calliper with a slight mod. If you do go down this route check with dax, Can't remember if it was 2wd or 4wd Cosworth discs that they use.
Not sure what you are doing but it might be of some help.
Mark
ned
posted on 5/2/04 at 09:40 AM Reply With Quote
On a locost or mkindy I'd be very suprised if you actually benefitted from bigger disks upfront. With standard disks, calipers and some decent pads you should be fine. Also bear in mind bigger discs will be heavier and will add to the unsprung mass of the car, thus adding detrimental affects to the handling. Either way I doubt you'd notice any difference. save your money and spend it on another part of the car!
If you are dead set on imprving the brakes you'd get a better improvement by spending your money on some nice light wilwood calipers.
just my 2p..
Ned.
beware, I've got yellow skin
200mph
posted on 5/2/04 at 09:49 AM Reply With Quote
yeah, would agree with ned!
Saving my pennies to get willwoods, as a nice four pot conversion can be yours for under £400.
Mark
Graceland
posted on 25/2/04 at 11:18 AM Reply With Quote
how do the bigger disks, pads and calipers add to the unsprung mass of the body ned? they are attatched to the hub remember and this is sat between 2 wishbones connected to the body, so really, the disks, pads, calipers have nothing to do with the overall mass of the unsprung chassis/body combo
just an observation
Jon Ison
posted on 25/2/04 at 11:25 AM Reply With Quote
simple, they add unsprung weight, lighter brakes is defo the way to go on such a light car...........
Graceland
posted on 25/2/04 at 11:33 AM Reply With Quote
ahhhhh but ned mentioned the unsprung mass of the car, not each hub assembly
i'll get me coat
Jon Ison
posted on 25/2/04 at 11:38 AM Reply With Quote
ohhhhhhhhh you piccy iccle bugger, as bad as our lass.........
seriously though there aint no need to go over the top on braking, quality light weight calipers, small discs and good pads, bigger brakes may not even get up to temp and prove less effective than standard set ups
mackie
posted on 25/2/04 at 11:47 AM Reply With Quote
Graceland, the unsprung weight of a car is the weight of all the unsuspended components, namely wheels, tyres, brakes, hubs and a portion of the suspension arms. The lower it is the better since lower interia and momentum means the suspension can react quicker and more accurately. At least that's how I understand it, I'm no chassis engineer though (well maybe an amateur one ).
[Edited on 25/2/04 by mackie]
Stu16v
posted on 26/2/04 at 07:55 PM Reply With Quote
And I understood it to mean exactly as mackie has just described.
The rest of the car is sprung mass-i.e. the 'other side' of the springs (or in other words, the bit of the car that is held up by the springs....).
Graceland
posted on 26/2/04 at 08:07 PM Reply With Quote
*whistles*
NS Dev
posted on 25/3/04 at 11:22 PM Reply With Quote
I used 2wd cosworth discs and 4pot calipers on my rally car. The discs are flipping heavy and I wouldn't want them on my locost!
