Author: Subject: Help with name of a component.
r1_pete
posted on 26/1/16 at 02:33 PM Reply With Quote
I'm trying to find some rubber mountings, often seen on motorcycle fairings etc...
Its a square section rubber grommet which fits in the panel, with a crush tube though it, and large washer on each side. Which gives a slightly flexible mounting and spreads the load of the mounting point..
Is there a generic name for them, searching fairing grommets etc. results in single components with the bike related price hike, rather than per volume...
Cheers.
Pete.
posted on 26/1/16 at 02:39 PM Reply With Quote
I would start with a "grommet" but be prepared for something different.
Worth speaking to a motorbike dealer for advice?
ianhurley20
posted on 26/1/16 at 02:53 PM Reply With Quote
I think what you are talking about are 'rivnuts'. Not the metal type but rubber rivnuts. That what I bought for my sons motorcycle fairing
MP3C
posted on 26/1/16 at 02:56 PM Reply With Quote
The only thing i can think of which is simlar to what you are describing is M10 Female Anti Vibration Rubber Mounts Isolators Bobbins 40mm x 50mm Not sure if it is what you are after...
Hope it helps..
Matt
Edit, I re-read your post and I dont think what I have said bairs any resembelance. sorry.
[Edited on 26/1/16 by MP3C]
Doctor Derek Doctors
posted on 26/1/16 at 02:57 PM Reply With Quote
AV (anti vibration) Grommet? or AV Mount?
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
ianhurley20
posted on 26/1/16 at 03:01 PM Reply With Quote
http://www.memfast.co.uk/shop/Vprod2.asp?cat=2256003708
Rosco86
posted on 26/1/16 at 03:11 PM Reply With Quote
also called "well nuts"
My Build Thread
computid
posted on 26/1/16 at 03:18 PM Reply With Quote
They're called Steel Top Hats and Rubber Grommets. You can get some here:
Steel Tophats & Rubber Grommets Motorcycle Fairings Set of 10 for Harley KTM
Adam
loggyboy
^^This^^^
Mistral Motorsport
Benzine
posted on 26/1/16 at 04:18 PM Reply With Quote
Flushed grollings? Olive spantles?
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 26/1/16 at 06:13 PM Reply With Quote
What about something like the mounting feet on the old Lucas wiper motors......
