Author: Subject: machining favour
luke2152
posted on 28/7/16 at 08:03 PM Reply With Quote
machining favour
Can someone with a lathe do a little job for me for cash or beers.
Need a 36-1 trigger wheel for a bike engine to replace the stock 4 tooth one. I have a suitably sized 36-1 wheel. Stock one needs to be cut back to leave about 24mm and then the new wheel drilled same size so I can tack weld it in place.
Cheers.
http://s1288.photobucket.com/user/luke_2152/media/20160728_204822_zpspysylqak.jpg.html?filters[user]=136982785&filters[recent]=1&sort=1&o= 0
theprisioner
posted on 29/7/16 at 08:22 AM Reply With Quote
I don't understand fully, I assume you want the existing wheel turned off and the new one bored out and fitted to the old shaft? If you are not in a hurray and the distance (Scotland) is not an issue then drop it off in the post.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
luke2152
posted on 29/7/16 at 02:22 PM Reply With Quote
Yes exactly as you describe. PM sent
CosKev3
posted on 29/7/16 at 04:40 PM Reply With Quote
Being nosey, whee did you get tell 36-1 wheel from and what diameter is it please?
luke2152
posted on 29/7/16 at 05:54 PM Reply With Quote
Its from the rather un-originally named trigger-wheels.com. Mine is 51mm diameter -the smallest but they do a variety of sizes.
CosKev3
posted on 29/7/16 at 08:17 PM Reply With Quote
Nice one thanks
