Author: Subject: duratec donor
PSJ282
posted on 18/2/17 at 03:15 PM Reply With Quote
duratec donor
hi all was wondering what would be the best option for a 2.0 duratec motor
Mazda or ford, pros and cons, best donor with most parts to convert to rwd, maybe something that has a ecu that can be reused without the whole loom needing to come too, also heard some may come with a better option for water rail??
all advised is appreciated so thanks in advance
ed
big-vee-twin
posted on 19/2/17 at 08:51 PM Reply With Quote
The ST150 motor is the best to get, it has larger ports in the head, blanked off EGR and also a single mass flywheel.
I used Megasquirt to manage the engine, don't know anyone who has used stock ECU.
http://www.triangleltd.com
bj928
posted on 11/8/17 at 05:42 AM Reply With Quote
if you want real power, the 2.3 ecoboost in the mustang is a turbo duratec as far as i'm aware, same engine as the focus rs as far as my research goes, the mustang version con be got in manual rwd 6 speed, don't know if anyone has tried this engine in a kit car yet
