New Topic New Reply
Author: Subject: i'm mad
mad4x4
posted on 16/11/17 at 10:27 PM Reply With Quote
i'm mad
Well i'm mad.... official.
Have successfully managed to drop a v6 Jag engine and gearbox into the MK indy chassis and got all the engine and gearbox mounts made. Next bit is to figure where to put the twin exhausts, currently each down pipe is sitting infront of the foot wells and will be kicked out to the side and then along runnig 3 cyclinders into each exhaust.... Then its brakes, wiring and tryign to get the bonnet back on.
[img]https://photos.app.goo.gl/A9g2PQIsliAoaBy03[/img]
Scot's do it better in Kilts.
40inches
posted on 16/11/17 at 11:16 PM Reply With Quote
If it's any help this is how I have done mine. More photos in my archive in the AJ30 folder
SJ
posted on 17/11/17 at 08:12 AM Reply With Quote
Looks like great work, but isn't that exhaust going to be too low?
40inches
posted on 17/11/17 at 08:30 AM Reply With Quote
Not in over 1000miles over some very rough roads. The gearbox bell housing has the same ground clearance
posted on 17/11/17 at 02:38 PM Reply With Quote
You think your mad? Shoehorning a rover v8 into my Jago but trying to keep it looking stock!
Pojo
posted on 18/11/17 at 03:26 PM Reply With Quote
This is how much room you have in a Luego Viento chassis, plan is to run LH exhaust in front of engine to join up with RH exhaust and single silencer
40inches
posted on 18/11/17 at 03:49 PM Reply With Quote
It's a bit tighter in the MK chassis
big_wasa
posted on 18/11/17 at 04:14 PM Reply With Quote
That’s a lot of engine to stick in there
Badger_McLetcher
posted on 18/11/17 at 05:59 PM Reply With Quote
Welcome to the club
[Edited on 18/11/17 by Badger_McLetcher]
If disfunction is a function, then I must be some kind of genius.
big_wasa
posted on 18/11/17 at 07:45 PM Reply With Quote
So I’ve got an St220 lump that will run Oem injection.
So what are my rwd options. What’s the jag ratios like in the real world ? What fly’ and clutch.
New Topic New Reply
