Author: Subject: foot pump - recommendation
posted on 25/4/18 at 01:21 PM Reply With Quote
Bought a double barrel footpump, like the one below.
Today I had to use it so after stamping away like an effing maniac and not seeing any change nor pressure registered on the gauge, investigation revealed the hose has perished - I can pick pieces off it using fingers.
So
a) I am looking for a reliable foot pump - recommendations (not electric)
and
b) car valve adapter than can be fitted to a hose as it may be possible to fix it.
mackei23b
posted on 25/4/18 at 01:53 PM Reply With Quote
Hopw about one of these...
https://www.aldi.co.uk/auto-xs-digital-footpump/p/082690204675600?gclid=EAIaIQobChMI_8_csMnV2gIV7r3tCh3njwzOEAQYASABEgKy1fD_BwE&gclsrc=aw.ds&d clid=COj--rHJ1doCFbIh0wodmaoJbA
https://www.aldi.co.uk/auto-xs-digital-footpump/p/082690204675600?gclid=EAIaIQobChMI_8_csMnV2gIV7r3tCh3njwzOEAQYASABEgKy1 fD_BwE&gclsrc=aw.ds&dclid=COj--rHJ1doCFbIh0wodmaoJbA
ian locostzx9rc2
posted on 25/4/18 at 02:01 PM Reply With Quote
I got a double pump one from Halfords works ok
907
posted on 25/4/18 at 02:48 PM Reply With Quote
You can get a new 'oze from the fork 'andle shop.
Paul G
dinosaurjuice
posted on 25/4/18 at 03:25 PM Reply With Quote
I gave up on foot pumps years ago and started using a bicycle 'track pump'. Might not be suitable due to shape/size though...
jps
posted on 25/4/18 at 04:16 PM Reply With Quote
If you mean parts to fix your current footpump - you can get parts to fix bike track pumps which I assume will be compatible - but price may put you off
Tope ak pump parts
[Edited on 25/4/18 by jps]
907
posted on 25/4/18 at 04:59 PM Reply With Quote
£1.99
eBay Item
posted on 25/4/18 at 05:04 PM Reply With Quote
Had the same perished hose issue with a cheap foot pump from Halfords. Threw it in the bin and bought a bicycle track pump from eBay. Worked well for bicycles, cars and footballs for 5 years now.
Jed
posted on 25/4/18 at 06:56 PM Reply With Quote
Get one of the hoses listed above and if the pump doesn't work well afterwards then get a used Dunlop Major (several on eBay) and use the newly purchased hose on that. I gave up on the cheap pumps and have a Major in each garage and they're great.
steve m
posted on 25/4/18 at 09:49 PM Reply With Quote
A FOOT PUMP ??
how 1970's, infact ive not even seen one since then. I know my Dad had one, and its probably still in his garage, buts hes not driven in 20 years, thankfully!
I ll put it on ebay for you, maybe worth £100 as its so fing old
posted on 26/4/18 at 09:15 AM Reply With Quote
I know you said not electric, but I picked on of these up for £1 in Aldi yesterday. Figured if it worked bargain, if not throw it away.
It works off the car cigarette lighter socket and pumps car and bike tyres + footballs.
(Schrader valves + a pin adapter for footballs)
[Edited on 26/4/18 by nick205]
posted on 26/4/18 at 03:01 PM Reply With Quote
temporarily fixed it with 4 mm PVC air line; expected the it to blow off but managed to pump up the tyre.
I do have a track pump but that is 105 miles away from me.
907
posted on 26/4/18 at 03:42 PM Reply With Quote
The track pump will require a longer line.
