Author: Subject: Instruments
tr
posted on 21/2/03 at 11:10 PM Reply With Quote
Instruments
I'm just in the process of ripping my donor vehicle to bits and had a few questions regarding paperwork. I've declared the car sorn and I'm waiting for the reply from the DVLA. Last week I pulled the instument's out of the dash, and it occured to me, what do I do with the odometer? I plan to get a new speedo eventualy. Do I transfer the clock reading from this to the new one? Do I need to register this milage with anyone?
Any help would be apreciated.
Ta'very much
tr
theconrodkid
posted on 22/2/03 at 03:17 PM Reply With Quote
you aim the speedo in the nearest bin and start at 0 miles
who cares who wins
pass the pork pies
tr
posted on 24/2/03 at 09:44 PM Reply With Quote
Thats refreshingly easy. I expected at least *some* red tape.
Cheers.
tr
stephen_gusterson
posted on 24/2/03 at 10:47 PM Reply With Quote
dont matter at all
your car will be classed as being built from old parts.
I does not need to have a recognised identity so you can set anythign to anything yer like as long as it meets sva.
atb
steve
Northy
posted on 27/2/03 at 10:02 PM Reply With Quote
I have heard that if you use the donor gearbox, diff, wheels and speedo they don't bother to check the accuracy of the speedo at SVA! And even if they do, it's likely to be right.
Worth doing? You can always change them afterwards.
Graham
david walker
posted on 8/3/03 at 08:25 PM Reply With Quote
I think that's unlikely Northy. When you go for the SVA your car will be run up on the speed rollers as matter of routine and checks made every 10mph. A printout is then produced of actual versus shown readings. You can show a bit over but none under actual speed.
The examiner only wants to know the origin of the engine and won't ask (other than for general interests sake) about the rest of the running gear.
That said if all the parts went together on the original car you are unlikely to have a problem.
I ran with an RS2000 gearbox, 1600 Escort diff, XR3i wheels and Dolly Sprint instruments and mine was spot on!
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
geoff shep
posted on 9/3/03 at 09:34 AM Reply With Quote
I started trying to reset the odo to zero by connecting an electric drill but soon realised it would take some time! - eventually by a bit of persuasion managed to turn the tumblers individually back to zero.
Unless you know the history of your donor you've no real way of knowing whether the odo is even close to the actual mileage - my blue donor turned out to have the front right quarter of a brown car welded into it.
