Author: Subject: Alloy sierra rear calipers
R1minimagic
posted on 16/1/06 at 07:28 PM Reply With Quote
Where can i get some and how much?
martthefridgeman
posted on 16/1/06 at 07:34 PM Reply With Quote
try rallydesign
http://www.rallydesign.co.uk/catalog/default.php
about £60 +vat each
JAG
posted on 16/1/06 at 07:35 PM Reply With Quote
Being pedantic - the Sierra never had Alloy rear calipers. They were cast Iron.
Those from Rally Design were designed for a VW vehicle. What caliper bore size are they??
Justin
highspeeddirt
posted on 16/1/06 at 07:39 PM Reply With Quote
I think Hispec has finally released their Sierra rear brake set up. I see that Fisher Sportscars/The Kit Car Workshop have them listed in their Ebay shop.
R1minimagic
posted on 16/1/06 at 07:40 PM Reply With Quote
I know that, otherwise i could just go to Ford and get some!!! Lol!!
Are those HiSpec ones for front or rear?
[Edited on 16/1/06 by R1minimagic]
G.Man
posted on 16/1/06 at 08:51 PM Reply With Quote
I am fiting the rally design ones as the hispec ones bend the disk alledgedlly...
Opinions are like backsides..
gazza285
posted on 16/1/06 at 10:18 PM Reply With Quote
Why not use Citroen/Peugeot alloy rear calipers.
JoaoCaldeira
posted on 17/1/06 at 08:40 AM Reply With Quote
Hi.
Do you know if this VW callipers are direct replacement for the Sierra ones? (I suppose you have the Sierra now fitted...)
If not, will you make an adaptor mount?
Thanks in advance,
Joao Caldeira
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
Building: a pile of bits that will someday be a fisher fury
posted on 17/1/06 at 12:05 PM Reply With Quote
they wont bend the disk that much if the hand brake is properly sorted as the force needed to stop a light locost or other kitcar from moving will be fairly low and the disks are very stiff esp if using vented disks. the only time there would be a problem is if the disk was very hot and the hand brake was put on as it might warp the disk but even normal handbrakes and hot disks are a bad idea.
uklee70
posted on 17/1/06 at 12:08 PM Reply With Quote
I have a pair of the rally design calipers for sale
as I have had to change plans as they dont fit under 13" rims
I can send them back to rally design so make a sensible offer if you want them
Lee
smart51
posted on 17/1/06 at 12:21 PM Reply With Quote
Originally posted by cossey
if the disk was very hot and the hand brake was put on as it might warp the disc
That's why I wince when I see people at traffic lights with their brake lights on rather than using the hand brake. The foot brake will warp all 4 discs whereas the handbrake only does in the rears.
G.Man
posted on 17/1/06 at 02:52 PM Reply With Quote
Ah well as I dont have a brake disk temp gauge I will stick with the proper compensating calipers
mk blade
posted on 17/1/06 at 05:09 PM Reply With Quote
wilwood are now doing a ali 4 pot with handbrake.
rally design sell them
http://www.rallydesign.co.uk/catalog/product_info.php?manufacturers_id=45&products_id=11370
G.Man
posted on 17/1/06 at 09:07 PM Reply With Quote
Tony.
Nice
Thats the way it should be done
May not be self adjusting, but I could live with that..
andygtt
posted on 18/1/06 at 06:48 PM Reply With Quote
Thats what I am fitting on my car... they are £119+vat
please redefine your limits.
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
posted on 18/1/06 at 08:44 PM Reply With Quote
unless theyve benn absolutely thrashing their cars then i wont be a problem. most modern cars have brakes design to stop the car from well over 100mph so driving around at 30-40mph wont really get them anywhere near hot enough to warp the disks esp with vented disks.
the only time it could be a problem is trackdays where some people dont think and after having cain the brakes for a few laps come into the pits and leave the handbrake on.
