Author: Subject: large rear wheel
joolsmi16
posted on 15/11/07 at 02:21 PM Reply With Quote
large rear wheel
Hi all, just been looking at the Radicals and have noticed that they run a 15" at the Front and 16" at the Rear. Why is this done and what are the benefits?
Been thinking of running 17"on the rear with 15" at the front just for cosmetics but would like to know pros and cons before hand.
Jools
nitram38
posted on 15/11/07 at 02:25 PM Reply With Quote
It may raise the rear and improve handling?
Hammerhead
posted on 15/11/07 at 02:34 PM Reply With Quote
lotus do it with the elise 15" fronts and 16" rears. Exige 16" fronts and 17" rears.
I believe they do it because the engine is in the back.
v8kid
posted on 15/11/07 at 02:35 PM Reply With Quote
I run 15" front and 17" rear just because it suits the tyres that are available in the widths and compounds I want. I sustect in Radicals case it may be as simple as that
Duncan_P
Lotus did this on the Elise as well so there must be a fairly sensible reason behind it which im sure that someone with more knowledge than me will be a long to explain shortly
My guess would be something to do with tyre dynamics....generally higher profile tyres are easier to control on the limit and i would presume this effect is greatest at front so thus smaller wheels with higher profile tyres at the front
zilspeed
posted on 15/11/07 at 03:04 PM Reply With Quote
Gives the car a degree of rake front to rear which is desirable / necessary.
Hopefully someone who knows more than I do will be along soon.
_Aero_
posted on 15/11/07 at 03:07 PM Reply With Quote
Originally posted by zilspeed
Gives the car a degree of rake front to rear which is desirable / necessary. Depends on the ride height surely?
joolsmi16
posted on 15/11/07 at 05:21 PM Reply With Quote
rear tyre
I have 195/50/15 ET38 at the front and if I put 240/50/17 ET42 on the rear.
Can anyone tell me what effect this will have on my wheel alignment? with 15" at the front and rear the track widths are the same.
joolsmi16
posted on 15/11/07 at 05:28 PM Reply With Quote
rear wheel
Rear tyre is 245/50/17!
andygtt
posted on 15/11/07 at 09:18 PM Reply With Quote
Gearing?
you get no gain by having a large wheel on the front but you do at the rear... and you don't want differing tyre profiles front and rear.
Another is looks as it makes the car look more balanced... but I doubt radical care about that.
edited to add that I am guessing as I don't know for sure.
[Edited on 15/11/07 by andygtt]
please redefine your limits.
Hammerhead
posted on 16/11/07 at 12:30 PM Reply With Quote
on the elise the tyre profiles are different to correct the rolling radius from using different diametre wheels.
