posted on 6/10/15 at 03:44 PM |
MIG welding tintop bodywork
Hi All,
With time to kill I'm contemplating some restoration work on my F reg 205 GTI. It needs a new drivers sill and some boot floor patches doing.
My MIG welding is OK, but I've not tackled thin sheet much without making holes.
Other than practice what techniques do people recommend applying to get this right?
Nick
jacko
posted on 6/10/15 at 04:11 PM |
spot welds rather then long welds and don't try and weld a lot in one place weld in different parts of the patch
jacko
posted on 6/10/15 at 04:14 PM |
That concurs with the pros on youtube!
steve m
posted on 6/10/15 at 04:29 PM |
Disconnect the battery and alternator
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
loggyboy
posted on 6/10/15 at 04:43 PM |
Buy a jogler.
Mistral Motorsport
theconrodkid
posted on 6/10/15 at 04:47 PM |
as above,jogglers are well worth it,try to get the double headed one that also punches holes
who cares who wins
pass the pork pies
owelly
posted on 6/10/15 at 05:36 PM |
Think clean!! Clean metal welds better than rusty/painted/greasy steel. Keep your MIG wire dry. Keep it indoors if your workshop is cold or damp. If
you've run dusty (rusty) wire through the gun, remove wire and blow through with an airline.
Keep weld-gaps small and weld with small blob-tacks. Keep the panels cool by moving around the patch. Keep blobbing untill all the blobs join up.
Flatten welds with a flap-wheel in the grinder.
http://www.ppcmag.co.uk
ianhurley20
posted on 6/10/15 at 10:06 PM |
Watch Project Binky on You Tube. Some brilliant welding to watch and learn particularly when you get to episode 8 - ish where Nik welds the boot panel
on a Mini. As said before, spot weld and move on to avoid heat build up and holes, better still use the joggler to make a lip, punch a hole and spot
weld through the hole - all demonstrated on Project Binky
[Edited on 6/10/15 by ianhurley20]
Oddified
posted on 6/10/15 at 10:08 PM |
All the above, but i also find the Co2/argon mix is better for doing thin body work steel.
Ian
907
posted on 7/10/15 at 06:46 AM |
Nobody ever mentions it but with car restoration welding is only 10% of the story.
By far the greatest skill needed is sheet metal work, which when done to a high standard
makes the welding easier anyway.
All IMHO.
Paul G
Rosco86
posted on 7/10/15 at 06:51 AM |
Ian
this is so true! after using co2 for the last 5 years i have just changed to a proper welding bottle and its like i have learnt to weld overnight!!
also you can get mig torch shrouds that have two little legs specially for spot welding
My Build Thread
posted on 7/10/15 at 07:51 AM |
Ian
Where can you get the spot welding shrouds from?
Rosco86
posted on 7/10/15 at 08:51 AM |
any welding supplies shop i would have thought or link below
ebay
[Edited on 7/10/15 by Rosco86]
My Build Thread
posted on 7/10/15 at 09:17 AM |
That looks interesting!
[img]
![](/galpreviews/MIG shroud.JPG) ![MIG shroud](/gallery/MIG shroud.JPG) MIG shroud
[/img]
posted on 7/10/15 at 09:18 AM |
I should add that I plan to spend less time welding and more time prepping!
posted on 7/10/15 at 10:52 AM |
All IMHO.
Paul G
True - I do have another bodyshell to cut sections from to help with this, but it's not immaculate
posted on 7/10/15 at 11:17 AM |
May well invest in one of these too...
![](/galpreviews/jogler.JPG) ![jogler](/gallery/jogler.JPG) jogler
Rosco86
posted on 7/10/15 at 11:21 AM |
i do have a brand new sealey one, still in the box if your interested?
My Build Thread
keithjardine
posted on 7/10/15 at 11:42 AM |
As above, spot weld and keep moving the weld site to reduce heat build up.
Joggler is good if you have space, butt welds are tricky-I used 0.9mm wire and 1.2mm sheet steel to replace rust/gaps.
I borrowed a gasless mig (they are generally regarded as crap) but with 1mm sheet it was plenty powerful.
Have lots of flap discs at hand!!
Be prepared to chop out more rust to get to good metal, trying to weld rusty thin metal is not worth the effort.
Are the replacement sill sections any good?
I assume you are going to drown it in Dinitrol or an alternative rust protection too?
posted on 7/10/15 at 11:55 AM |
Rust protection is another worry long term, but it'll be well painted where I can get to it.
Garage life and dry life should help it along!
keithjardine
posted on 7/10/15 at 12:07 PM |
Dinitrol is widely regarded as being very good and relatively user friendly
http://www.rejel.com/rejel-store/classic-kits.aspx
http://www.frost.co.uk/dinitrol-rust-proof-kit.html
posted on 7/10/15 at 01:49 PM |
Will look it up before starting!
Minds me of a story on here about a Land Rover chap getting it all over the house and his cat while SWMBO was out.
posted on 13/10/15 at 03:34 PM |
Oooops - Argoshield gas has run out and I can't drive to the welding supplier for a refill - SWMBO will have to give me lift!
