Author: Subject: Luego Velocity Build Manual.
StevieH655
posted on 30/10/16 at 12:50 PM Reply With Quote
I have purchased a part built Luego Velocity. Can anybody help with a complete build manual please ? The one that came with the car is incomplete .
posted on 30/10/16 at 01:59 PM Reply With Quote
Welcome to the forum , can't help with a build manual as I've never seen a complete one. My car isn't a Velocity
but as the two share what is basically the same chassis I may be able to have with any specific enquiries. I would strongly recommend
having a good look through the Luego section of the forum especially with regards to the crush tube issue. How far did the original
builder get? If not already done fit the drivers side front tunnel panel before fitting the pedal box.. I'm sure others will be along with more help
posted on 30/10/16 at 02:01 PM Reply With Quote
PS put your location in your profile , there may be Velocity owners local to you?
jollygreengiant
posted on 30/10/16 at 05:31 PM Reply With Quote
Yep, second that rusty, location, even approximate area is nice, and, helpful. I'm sure could locate my old Viento build CD, it about the same as the Velocity, just bigger.
matt5964
posted on 30/10/16 at 08:53 PM Reply With Quote
U2u me you email address and I will email it over to you
It's the XT build manual I've got but should be the same
Luego velocity XT 2.0ltr 221.3bhp 178.9lbft
StevieH655
posted on 31/10/16 at 10:16 PM Reply With Quote
Thank you for the kind responses. I'm new to this so will get my profile sorted. Live in Dudley West Mids. Bought car partly built but have dismantled it back to parts because of certain issues with the standard of work. Main problem is the top insert of the sierra front upright. The ball joint is at an angle to the top of the insert which has resulted in the dust cover being chewed up. Hence the need for a manual so i can check the angle of the top wishbone threaded tube , it appears to be wrong.
Irony
posted on 31/10/16 at 10:42 PM Reply With Quote
Post some pictures because luego wishbones I think are a standard part so are unlikely to be wrong unless your previous owner bodged some of his own up.
posted on 1/11/16 at 07:31 PM Reply With Quote
If you have a bare chassis it might be worth checking the powder coating for any damage, mine fell off in sheets
Kev1n
posted on 2/5/17 at 02:03 PM Reply With Quote
Hi everyone.
I have just got a luego velocity.
Can I please ask nicely for a copy of the build manual PDF
Much appreciated.
Kev
matt5964
posted on 2/5/17 at 03:05 PM Reply With Quote
U2U me your email address and I will send one over, think it's a word document
