Author: Subject: Starter motor for ST170 engine on type9 box
t3nay
Contributor
Posts 20
Registered 16/5/15
Location Okehampton
Member Is Offline
Photo Archive Go!
Building: Always improving my Sylva Striker, MK2 Escort Mexi
posted on 17/5/20 at 12:58 PM Reply With Quote
Hi all, I’m after some advise.
I’ve fitted an st170 engine on a type 9 box and I’m struggling getting a starter to fit I was under the impression a pinto motor would do the job.
I’ve got a standard 1.8 flywheel and have kept the standard st sump but obviously cut all the alloy casting away where the started goes.
I think I just need a starter with a smaller diameter motor body?
Anyone got any ideas? Part numbers?
Thanks in advance
Tim
big_wasa
posted on 17/5/20 at 01:12 PM Reply With Quote
The pinto starter only works with a spacer on a standard zetec flywheel then only if it's not to fat.
The one you want is known as a Lucas Lrs707. These where fitted to the 1.8cvh and type9 and the 2.0 Dohc and Mt75.
Again no two starters are the same with some manufactures making them short and fat thin and long and somthing inbetween.
A lot of people have problems with these old starters doing the business on a hot zetec.
Much better is a gear reduction starter from three likes of powerlite and others. These are a proper zetec starter with the T9 flange.
tims31
posted on 17/5/20 at 01:13 PM Reply With Quote
I have a standard 2.0ltr Blacktop with a type 9 fitted, 1.8 flywheel and have used a LUCAS LRS707 Starter motor.
Works fine and had no problems. I'm sure big_wasa will be along soon and he'll know as he has a ST170
Build: http://www.martinsfurybuild.co.uk/
tims31
posted on 17/5/20 at 01:29 PM Reply With Quote
See I was right, but don't know how you posted beofre I had replied :-)
starterman
posted on 17/5/20 at 04:25 PM Reply With Quote
If you want an LRS707 at cost they are £48.66 delivered.
Mike
SJ
posted on 17/5/20 at 09:39 PM Reply With Quote
Mike, do you supply a hi-torque version that will overcome some of the hot starting issues often seen with this starter on a Zetec?
Thanks, Stu
t3nay
Contributor
Posts 20
Registered 16/5/15
Location Okehampton
Member Is Offline
Photo Archive Go!
posted on 18/5/20 at 09:38 AM Reply With Quote
Thanks guys for the advice.
And thanks Mike for the offer of the starter. I have ordered one through my local motor factors And should be with me tomorrow
Fingers crossed it will be swinging over tomorrow night.
starterman
posted on 18/5/20 at 06:32 PM Reply With Quote
Why didn't you just come to Callington and you could have picked one up from me
t3nay
Contributor
Posts 20
Registered 16/5/15
Location Okehampton
Member Is Offline
Photo Archive Go!
posted on 18/5/20 at 08:42 PM Reply With Quote
Oh bugger, I didn’t realise you were in Callington.
