<<  1    2    3  >>
Author: Subject: Paddle shift kits
pathfinder
posted on 23/3/06 at 09:15 PM Reply With Quote
Paddle shift kits
Evening all!
I’m making a paddle shift for my bec and thought id ask if anyone on here would be interested in one! It uses both the standard sierra steering column bearings and is width adjustable from 280mm down to 230mm so should fit most steering wheels! At this stage there is no provision for retaining standard sierra switch gear (may make a mk2 model later). Drawings are being sent to the laser cutters early next week so if anyone wants one I will add you to my order. All other parts will be professionally made and powder coated (anodizing offered at extra charge)!
Final price will be dependant on numbers ordered but I estimate £60 give or take £5!!!
Regards
locoboy
posted on 23/3/06 at 09:19 PM Reply With Quote
very interested.
Roll up roll up.........
Locoboy
Oooh, that looks nice. If the finished product looks half as good as that, we'll be interested. How much extra for the anodised finish?
[Edited on 23-3-06 by Hellfire]
shortie
posted on 23/3/06 at 09:26 PM Reply With Quote
I'd be interested definitely
pathfinder
posted on 23/3/06 at 09:27 PM Reply With Quote
Not to sure how much the anodizing will be (dependant on quantity again) wouldn’t think more than a tenner! Just to clarify the stem shown in the rendering will be powder coated black because its steel all other parts can be powder coated, polished, anodized or left raw!
skydivepaul
posted on 23/3/06 at 09:42 PM Reply With Quote
I'd be interested at that price. Although i would want the + on the right and the - on the left. Could you build in ali to save some weight??
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
skydivepaul
HD CCTV
IP security systems
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
Building: a pile of bits that will someday be a fisher fury
posted on 23/3/06 at 09:48 PM Reply With Quote
sorry for being pedantic but arent the paddles the wrong way round (+ should be on the right)
ChrisGamlin
Looks really good! How would a linkage mount to it, does it have bosses on the back to attach rods to?
How much would it be to just supply the paddle assembly, as my column is a bespoke jobbie which I wouldnt want to lose, but could weld on the appropriate pivot points? Id be interested in anodizing too.
cheers
Chris
pathfinder
posted on 23/3/06 at 09:52 PM Reply With Quote
The + and – paddles are reversible! The black part in the rendering is the only steel part (thin wall tube) and it doesn’t way much at all, would prefer to keep it steel as it makes manufacturing easier!
carlgeldard
posted on 23/3/06 at 09:59 PM Reply With Quote
Put me down for one I like it. Any chance of changing the design to include countersink set screws.
Carl
southpaw
posted on 23/3/06 at 10:00 PM Reply With Quote
How easy are these to fit?
Pezza
posted on 23/3/06 at 10:04 PM Reply With Quote
you can scratch me up for one too at that price
pathfinder
posted on 23/3/06 at 10:06 PM Reply With Quote
Chris
I’m picking up some m6 female clevis ends tomorrow and am planning to use one of these bolted to the back of the paddle using a alan bolt, however I have also thought about making a mount from aluminium angle for more adjustability!
the paddle is laser cut to fit the collar, I can fabricate a special stem if you wanted!
hearnia
posted on 23/3/06 at 10:13 PM Reply With Quote
Yep chalk me down for one too...
pathfinder
posted on 23/3/06 at 10:25 PM Reply With Quote
It’s very simple to fit, it’s a direct replacement for the sierra aluminium steering lock and black steering column sleeve. The bottom bearing carrier needs no be adapted and the top bearing removed from your aluminium casting! If you can build a car you can fit one of these in 30mins!
pathfinder
posted on 23/3/06 at 10:45 PM Reply With Quote
Carl
There is enough meat in the ali for countersunk set screws but iv got a draw full of button head bolts that I would prefer to use up first! You could adapt it yourself!!!
JoaoCaldeira
posted on 23/3/06 at 11:12 PM Reply With Quote
I'll wait for mk 2 as I would like to keep the Sierra switches (want to have a clean dashboard)
Joao
richijenkin
posted on 24/3/06 at 02:05 AM Reply With Quote
blimey... I thought mine was good.. thats looking mint dude... nice one!!!!
Paddle On
Paddle On
posted on 24/3/06 at 08:37 AM Reply With Quote
Rich - if you're planning on keeping the rest of the car dry that steering wheel cover will have to go.
mandbsheldon
posted on 24/3/06 at 01:20 PM Reply With Quote
me, me, me
Leigh
Brooky
posted on 24/3/06 at 01:54 PM Reply With Quote
AAH go on , one for me too please.
TA.
Brooky
posted on 24/3/06 at 01:55 PM Reply With Quote
[Edited on 24/3/06 by Brooky]
skydivepaul
posted on 24/3/06 at 06:17 PM Reply With Quote
Put me down for one, sorry i thought the whole assembly would be steel from yout earlier post.
p.s. just to let you know i sent this message from my laptop by the poolside in florida
HD CCTV
IP security systems
ChrisGamlin
posted on 24/3/06 at 06:18 PM Reply With Quote
Chris
Cheers for that, my column is a single tube right the way up though (totally different to the Sierra design) so I wouldnt really be able to fit an additional column stem, but as long as your column stem is larger diameter than mine (which if its accomodating the Sierra inner column it will be) then my column will pass through the paddle collar so surely all Id need to do is mod the top of my column to replicate the stem you're providing, with threaded lugs top and bottom to accept the bolts that pass through the rod ends?
cheers
Chris
[Edited on 24/3/06 by ChrisGamlin]
<<  1    2    3  >>
