scudderfish
posted on 7/10/13 at 12:28 PM |
Ducting wanted
I need a length of ducting to connect a cone filter to this mahooosive hole on my new carb hat.
Everything I seem to find on ebay or CBS seems far too small. Any suggestions on what I can do?
Regards,
Dave
loggyboy
posted on 7/10/13 at 12:37 PM |
Pair of tights and an elastic band?
Mistral Motorsport
Macbeast
posted on 7/10/13 at 12:54 PM |
It would be useful to give the diameter required.
fesycresy
posted on 7/10/13 at 01:28 PM |
Single skin stainless steel flue. Is that plenum oval?
Let me have some sizes and see what I have in the stores.
scudderfish
posted on 7/10/13 at 03:51 PM |
Yes it is oval, so it'll need distorting at one end. I don't have dimensions to hand, but I'd estimate it as about 6" by
3". It'll be Tuesday night before I can come up with anything more accurate than that. When I was searching on ebay for 'air
duct' all I came up with was about 60mm diameter, which is never going to fit.
Thanks,
Dave
loggyboy
posted on 7/10/13 at 04:01 PM |
Doesnt the airfilter just sit inside that big 'thing'?
Mistral Motorsport
scudderfish
posted on 7/10/13 at 04:25 PM |
No. As far as I'm aware it's primarily meant to be used to plumb a supercharger or turbocharger into a carb and all filtering has been
done upstream. And before anyone suggests it, I am not sticking a charger on! (yet)
kenton
posted on 7/10/13 at 09:23 PM |
When i built my viento i bought some wire re-enforced silicon ducting from Europa. It was 5 years ago so i dont know if its still stocked. From memory
it was 72mm dia.
kenton
posted on 7/10/13 at 09:38 PM |
looked through my build file and found it
http://www.europaspares.com/hi-temp-air-brake-duct-silver.html
Comes in sizes up to 114mm dia.
scudderfish
posted on 8/10/13 at 05:35 PM |
£54 a metre though! ![](/images//smilies/shocked.gif)
scudderfish
posted on 8/10/13 at 05:37 PM |
The circumference of the oval is about 345mm so just a little too big for this http://www.wickes.co.uk/invt/713024 which is a much more reasonable
£7.69 for 4 metres.
Andybarbet
posted on 8/10/13 at 05:45 PM |
Could you fit a plate on the box cut 2 holes in the plate and feed two large pipes into it ?
I think I still have a few metres of wire reinforced flexi tubing, its about 2" diameter if its any good to you ??
scudderfish
posted on 8/10/13 at 07:42 PM |
Thanks for the offer, but 2 2" pipes wouldn't have the cross sectional area I need.
Regards,
Dave
kipper
posted on 9/10/13 at 12:30 PM |
pipes
Try Googling ARCO in Hull, they have a division that specialize in flexi pipes.
Denis.
Where did that go?
snakebelly
posted on 9/10/13 at 04:56 PM |
the other alternative would be to have an adapter made and welded on in Ally to bring the inlet down to a circle rather than an oval and make it a
common size at the same time? I know a man who can.
