Author: Subject: Reusing ARP Flywheel bolts
neilp1
posted on 31/1/17 at 04:27 PM Reply With Quote
Does anyone know how many times you can reuse ARP flywheel bolts??
pewe
posted on 31/1/17 at 05:11 PM Reply With Quote
Don't know about flywheel bolts but Guy Croft (he of Lancia/Fiat tuning fame) reckons ARP head bolts can be used three times.
HTH.
Cheers, Pewe10
Nickp
posted on 31/1/17 at 05:30 PM Reply With Quote
HTH.
Cheers, Pewe10
Yeah, then he'll sell you another set
pewe
posted on 31/1/17 at 05:32 PM Reply With Quote
HTH.
Cheers, Pewe10
- but they will be gold-plated
Nickp
posted on 31/1/17 at 05:37 PM Reply With Quote
HTH.
Cheers, Pewe10
As are the head gaskets, that don't actually fit, unless you're prepared to put a shift in!!
mcerd1
posted on 31/1/17 at 06:29 PM Reply With Quote
from ARP's site:
Are ARP bolts and studs re-usable?
Yes. As long as the fasteners have been installed and torqued correctly, and show no visible signs of damage, they can be re-used. If they show any signs of thread galling or corrosion, they should be replaced. In the case of rod bolts, if any of them have taken a permanent set and have stretched by .001” or longer, you should replace them immediately. See page 29 in the catalog for more detailed information on this critical measurement.
and it does say to contact them for any other info / questions....
neilp1
posted on 31/1/17 at 07:55 PM Reply With Quote
Originally posted by mcerd1
from ARP's site:
I sent them an email last week but they have not replied.
perksy
posted on 31/1/17 at 10:48 PM Reply With Quote
One thou on a rod bolt ain't much and you'd need to make sure you measured them before they were fitted so you knew what to compare the size to
I always get a bit twitchy with flywheel bolts, seen some of the damage that gets caused when it all goes pearshaped
chillis
posted on 1/2/17 at 01:24 PM Reply With Quote
Personally I never re-use flywheel bolts regardless of their manufacture, when the flywheel comes off so do your legs and I've grown quite fond of my legs and would not want to be without them. Thus new flywheel bolts seem a small price to pay.
Never under estimate the ingenuity of an idiot!
