Author: Subject: JGG's Progress on mr Bumble.
jollygreengiant
posted on 7/9/08 at 04:27 PM Reply With Quote
Well its still going a bit slower than I would like, I have been trying to get the exhaust finished so that I can fit the bonnet before going to Stafford this week ( too long a trip with an unfitted bonnet me thinks, even on a trailer). So I thought I would give you all a heads up on where I've got to.
With the wonderful help of TrevD (thank you indeed Trev) I got some side finishers made to go between the wheel arches and the sides like this :-
Nearside
Nearside finisher
Nearside finisher
nearside finisher from front
nearside finisher better angle
and offside
Offside finisher
Offside finisher
This has allowed me to fit the rear arches and wire in the light fittings
Rear arches fitted
Rear arches fitted
Also for the past week I have been progressing with the exhaust manifold from this :-
Exhaust started
Exhaust started
to this point
exhaust from back
exhaust from back
exhaust from front
exhaust from front
exhaust from side
exhaust from side
and yes from a purist point the are not all EXACTLY the same length, however they have all ended up with about an inch or just over being the difference in length and whilst perfect balance in length is desirable, it is not totally necessary and the difference in the bend angles will have an effect albeit slight. so it should not be too bad when finished. It took me ages to get the joint faces tight and get all the pipes pointing in the right direction. I now have to get the pipes seam welded and then I can fit the collector and pipe to exhaust box (and then polish).
So there you have it work goes on. I am now getting down to a finishing list.
Fit bonnet.
Fit ordered Seats (when they arrive, probably after next weekend)
Fit Seat belts
Fit cooling fan
Rear decking & boot lid.
Tyres & paint rims.
Front Grille
Possibly fit Speedo healer
Trim out for SVA
Put paper work in.
And its only been 4 years.
austin man
posted on 7/9/08 at 09:48 PM Reply With Quote
why do yo need a speedo healer are u using pinto to sierra box and diff ? if so what speedo ??
CaptainJosh
posted on 7/9/08 at 10:49 PM Reply With Quote
Good job with the exhaust
jollygreengiant
posted on 7/9/08 at 10:56 PM Reply With Quote
Different size off tyres and slightly better diff ratio.
speedyxjs
posted on 8/9/08 at 06:56 AM Reply With Quote
Looking good but i think you need to add to your list (at the end of course) clean car
oldtimer
posted on 8/9/08 at 07:05 AM Reply With Quote
Nice safety boots! or is barefoot welding a macho Northampton thing??!...
NeilP
posted on 8/9/08 at 07:27 PM Reply With Quote
Looking good JPG.
Time for a push on and digging out those forms I'd say!
p.s. Last job - Fit carpets
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
