Over winter I'll be adding some boot storage to my Locost for many reasons, but mainly so I have some storage for some tools.
I've bought myself a small toolbox and this weekend will be buying all the necessary items to fill it with!
So far I've got on my shopping list:
Insulation Tape
Cable Ties
Long Nose/Short Nose Pliers
Set of Allen keys
6 Screwdrivers of varying sizes - 3 slot, 3 Cross
Set of ring/open spanners (probably 11Nr going from 6-19mm)
LED Torch/Miners Light
Anything else I should consider take? (without getting too silly)
small cheapo multimeter, some terminals, scotch loks, spare cable, fuses
tow strap
If you can squeeze a small socket set in there, it's much easier to work with them
duct tape - you'd be amazed how many things can be 'fixed' with it
even seen someone make a CV boot out of it with a couple of cable ties after a breakdown a few hundred miles from home - and they claimed it got them
all the way home
Energizer LED head torches are quite good (got one out of tesco the other day for ~£4)
if you get a small socket set (1/4" drive) with some screwdriver bits then you don't need the carry all the different screwdrivers
(but keep a couple of flat ones to use as levers )
[Edited on 20/11/2013 by mcerd1]
Breakdown recovery card.
A hammer.
All tool kits should have at a minimum, a hammer and duct tape.
Gaffer tape, hammer, condom... If you can't fix it with the first 2 then...
Originally posted by mcerd1
even seen someone make a CV boot out of it with a couple of cable ties after a breakdown a few hundred miles from home - and they claimed it got them all the way home![]()
Hi
You are not going to do any substantial repairs at the roadside
a AA or? get you home service.
a tow rope if you want to call a friend.
a screwdriver magnetic with varied bits
a multitool.
insulating tape & a few connectors.
No need for spanners 4 post lift kitchen sink etc.
a sledge hammer to smash the F....in thing to bits.
Bus fare!
umbrella or plastic poncho
the evil tyre weld
if including a socket set I would go 3/8th drive, and include a spark plug spanner
dayglow / reflective vest.
Trailer to put it all in
I take a rac recovery card and a mobile
From past experience a gallon can of petrol, I have run out twice on long runs.
When I did the same thing for my motorbike, I gave the bike a full service and put all the tools in a pile, then worked my way through them seeking
ways to make things smaller/lighter/more compact.
I've ended up with a tool kit that with the exception of a couple of larger tools, can take the whole bike apart including the engine, but fits
into a Kriega tool roll. Add some spare spark plugs, tyre slime, co2 canisters and wiring/fuses/connectors and its been perfect. Cable ties are a
pretty good shout too, as is Duck Tape.
From experience, the thing most likely you leave you stranded at the road side is a puncture or electrical fault. Anything else will invariably
require you to carry a stack of spare parts with you, so only take enough tools to access and repair electrical bits and tyres and add an AA card to
your wallet.
The only reason I carry the tools I do on the bike is that I do some big bike rally challenge events and if you break down on that in the middle of a
forestry block and nowhere near a point of recovery, you really are Donald Ducked.
Jubalie ties
Spare clutch cable
Spare cable inner
Screw fit cable nipples
Sharp knife
20pound note in a sealed bag
All things I have in mine
