Author: Subject: TIG welding First attemp for about 10 years
r1_pete
posted on 23/3/13 at 02:39 PM Reply With Quote
Well, after owning the machine for 18 months I finally got round to getting an Argon bottle and giving it a try.
Seems to work fine on DC, pics below, but it will not work on AC, I've has a look inside and nothing obvious, connector loose / dropped off etc....
Switching to AC and striking up, all I get is one arc and then the error light comes on, anyone know a repairer I can take the unit to and get it checked out?
First go
First go
back view
back view
Brett Jones
posted on 23/3/13 at 02:47 PM Reply With Quote
Correct me if I'm wrong, but I thought DC was for steel and AC was for aluminium.
http://mnrvtecvortxbuild.blogspot.co.uk/
r1_pete
posted on 23/3/13 at 02:53 PM Reply With Quote
Yep, works fine on DC for steel etc.
AC for aluminium, which is mainly what I wanted it for - nothing.....
posted on 23/3/13 at 03:24 PM Reply With Quote
Try contacting plasmapart.com to see if they will look at it for you if it is a Chinese welder. Spectrum welding in Chesterfield might help but it can get expensive.
John Bonnett
posted on 23/3/13 at 05:41 PM Reply With Quote
First go
First go
back view
back view
Just a thought, but have you connected the torch to the negative output?
liam.mccaffrey
posted on 23/3/13 at 05:42 PM Reply With Quote
Was going to suggest plasmapart, they repaired my plasma cutter!
Build Blog
Build Photo Album
imp paul
posted on 23/3/13 at 07:33 PM Reply With Quote
u2 u sent
