<<  1    2  >>
Author: Subject: track days
craig5
posted on 19/6/15 at 01:00 PM Reply With Quote
track days
just bought a stm r1 and at moment the et is 0 as was used for hill climbs so anyone got any info what my best standard set would suit track days as a base to start with and what are regarded as best tyres
bi22le
posted on 19/6/15 at 01:06 PM Reply With Quote
A048 are commonly considered the best semi cut slick. They are pricey though. R888 are a little cheaper.
If you are considering changing your wheels then 15" will give you more tyre options.
13" are lighter.
ET generally seem all over the place. I guess the wider the track the better.
Please read my ring story:
craig5
posted on 19/6/15 at 01:47 PM Reply With Quote
they dont do the ao48 in 13's though
craig5
posted on 19/6/15 at 01:52 PM Reply With Quote
have 13 7 minilights at moment but the tyre size is 215 50 13 so can i change this as toyo dont make that size
Karl H
posted on 19/6/15 at 02:42 PM Reply With Quote
They do 888s in 225/45 R13 I'm no expert but is that close enough?
craig5
posted on 19/6/15 at 03:02 PM Reply With Quote
god know i just know how to drive i have spare set of alloys with 185 55 13 with avon zzr's on them can these go straight on car i have no idea haha
daniel mason
posted on 19/6/15 at 05:08 PM Reply With Quote
Does the car have a speedo Craig? If so where is the pickup?
If you could keep the tyre size the same the speedo should work the same.
If you keep these tyres for road use then you know it's accurate. For track work bolt some slicks on mate!
craig5
posted on 19/6/15 at 05:19 PM Reply With Quote
The speedo not working it has sensor that looks too far away from wheel mayb caûse he they were running et0 for hill climbs also has the piece of metal on alloys as the pick up
craig5
posted on 19/6/15 at 05:22 PM Reply With Quote
Was also given a 2nd set of alloys with 185 55 13 Avon zzr on have some receipts and looks like they are 13x6 the alloys
daniel mason
posted on 19/6/15 at 05:53 PM Reply With Quote
The pickup would generally not be on the wheel itself!
TimC
posted on 19/6/15 at 06:03 PM Reply With Quote
Err, yes they do.
craig5
posted on 19/6/15 at 06:12 PM Reply With Quote
where should it be poss rear drive shafts?
daniel mason
posted on 19/6/15 at 06:33 PM Reply With Quote
Anywhere you can get a mounting point for the sensor really
daniel mason
posted on 19/6/15 at 06:35 PM Reply With Quote
http://www.camskill.co.uk/m114b0s700p0/Track_Day_Tyres_-_Trackday_Tyres_-_Motorsport_Tyres_-_13_inch_R13_inch_-_205_60_13_205_60R13
daniel mason
posted on 19/6/15 at 06:36 PM Reply With Quote
http://www.camskill.co.uk/m114b0s673p0/Track_Day_Tyres_-_Trackday_Tyres_-_Motorsport_Tyres_-_13_inch_R13_inch_-_215_50_13_215_50R13
craig5
posted on 19/6/15 at 07:22 PM Reply With Quote
just spoke to phil and he said pick up always been on alloys and he originally had it on the 13 6 alloys but he removed and stuck in on the 13 7 now but it doesnt work
daniel mason
posted on 19/6/15 at 07:42 PM Reply With Quote
It's probably a spacing issue due to different width wheels and offsets. Which is why It would ge better to be relocated somewhere else which doesn't alter when wheels are swapped!
If your not too bothered about it,run the 6" rims on the road so th speed works and put some slicks on the 7" rims for track or competition use where you don't need a speedo
craig5
posted on 19/6/15 at 07:58 PM Reply With Quote
there is no blue light from sensor which it needs im told
jeffw
posted on 19/6/15 at 08:13 PM Reply With Quote
13" are lighter.
A048 are not the best semi-slick and 13" will give you the best choice of 1b tyres.
He got the 13" are lighter bit right.
Avon ZZR, ZZS or CR500, Toyo R888R or R888 are all good tyres. As you have ZZRs I'd give those a go. They do ZZRs in 215/50 13 as well. Make sure you are not using A24 compound ZZRs are they will overheat very quickly (typically used in Sprints & Hillclimbs).
craig5
posted on 19/6/15 at 08:21 PM Reply With Quote
theres not much life in them anyway was going to try the avon zzs
jeffw
posted on 19/6/15 at 08:44 PM Reply With Quote
ZZS looks like a good compromise.
daniel mason
posted on 19/6/15 at 08:47 PM Reply With Quote
My favourite of all the road tyres is the kumho v70/v700 but as JW says these can overheat in next to no time in the softest hillclimb compounds!
This is my take on things;
For road use I'd run the 6" wheels. With a 185/60/13 fr - 205/60/13 rear
With your spare set of 7" rims
If track days are your thing I'd opt for a good set of circuit slicks (these are very cheap to buy used)
If hillclimbing/sprinting in a roadgoing class I'd go for the kumho v70a In super soft compound
If hillclimbing/sprinting in non roadgoing just go Avon a15 slicks (you will have mega fun in these)
craig5
posted on 19/6/15 at 08:48 PM Reply With Quote
will go with them
craig5
posted on 19/6/15 at 08:50 PM Reply With Quote
daniel will be just light road use and id say few track day days a year at either oulton or ty croes
craig5
posted on 19/6/15 at 08:53 PM Reply With Quote
diff gona be replaced asap as been out in car today and way to short gona try a 3.6 but my biggest issue at moment is the koso dash not so much the speedo but the revs as will be hitting limiter all the time as it is at moment
<<  1    2  >>
