Author: Subject: duratec cam upgrade
andyhaase1
posted on 1/12/16 at 06:17 PM Reply With Quote
duratec cam upgrade
I have a set of new pipercross 300 camshafts to fit to my ST150 duratec engine, the kit comes with double valve springs and valve stem oil seals, but the paperwork says my pistons will need pocketing. Can anyone confirm this info please?
Andy c
View User's Profile View All Posts By User U2U Member   andyhaase1 's Aim
jtskips
posted on 1/12/16 at 09:07 PM Reply With Quote
without any doubt , If you take them out dunnel engines will do them ,think its about 40 pound a piston,but if your stripping it down shame your putting standard stuff back in, but could get quite pricey,or send them back and get some mild cams and your head ported at neil roper developments 400 should make it go a bit
andyhaase1
posted on 2/12/16 at 04:10 PM Reply With Quote
Thanks for confirming what I thought. I agree about putting old stuff back so I'm going for forged pistons and rods now. In for a penny, in for a pound or two!
laptoprob
posted on 3/12/16 at 09:01 PM Reply With Quote
Johns right, don't waste your money mate. You've done right going for high comp versions with steel rods, it will make the bottom end much more reliable and gain more power too.
http://www.youtube.com/watch?v=ajlF4nWJtGA
andyhaase1
posted on 4/12/16 at 05:02 PM Reply With Quote
Thanks, all stripped, bores deglazed, cleaned and first piston and rod in place. Only just discovered I don't own a socket for the arp bolts. Something else to buy!
jtskips
posted on 4/12/16 at 09:06 PM Reply With Quote
its only a multispline socket dont go buyin some special socket,
andyhaase1
posted on 4/12/16 at 09:23 PM Reply With Quote
Yes, I've got a bihex socket set somewhere!
jtskips
posted on 4/12/16 at 09:56 PM Reply With Quote
When you get your cams in you will find the valve caps being different sizes to get the right valve clearance you may have to get some different sizes ,got loads , no charge just post, let me know, j
andyhaase1
posted on 5/12/16 at 05:42 AM Reply With Quote
Ok thank you.👍
andyhaase1
posted on 8/1/17 at 10:37 AM Reply With Quote
jtskips, I've sent you a U2U.
andyhaase1
posted on 21/1/17 at 02:03 PM Reply With Quote
John, you have a new U2U.
andyhaase1
posted on 31/1/17 at 01:33 PM Reply With Quote
All sorted now thanks to jtskips!
Cheers John.
jtskips
posted on 31/1/17 at 08:00 PM Reply With Quote
No prob Andy glad i could help ,you have my number if you need anything else , john
