Author: Subject: Acewell 3250 Wiring Help?
smart1275gt
posted on 9/5/08 at 10:46 AM Reply With Quote
Just to clarify, does the Acewell have a permanent live supply or just ignition live at position one or two?
Cheers.
Paul TigerB6
posted on 9/5/08 at 11:14 AM Reply With Quote
I'm sure it will be the same as any other instruments and just have a switched live. Its only really sidelights, horn, rad fan and hazards that have a permanent live isnt it???
I stand corrected!!
[Edited on 9/5/08 by Paul TigerB6]
flak monkey
posted on 9/5/08 at 11:17 AM Reply With Quote
Needs a permanent live for the clock memory, but thats it.
Basically 5 wires IIRC
Perm live
Switched live
Earth
Rpm
Speed sensor
If you look on the acewell website you can d/l the instructions.
Sera
http://www.motosera.com
smart1275gt
posted on 9/5/08 at 11:18 AM Reply With Quote
Just thinking about the clock and odometer staying stored on the dash. Can't remember if it's got a built in battery?
smart1275gt
posted on 9/5/08 at 11:31 AM Reply With Quote
Not forgetting temp sender and fuel sender wires.
thanks for the info.
posted on 9/5/08 at 12:27 PM Reply With Quote
Yep, it has a permanant live feed for meory functions and clock and a switched live for the operational side.
I have a wiring diagram if you need it...
smart1275gt
posted on 9/5/08 at 01:26 PM Reply With Quote
Would be helpful, cheers.
smart1275gt@hotmail.com
