Haynes Roadster body tubs
Hugh Paterson - 30/9/17 at 07:15 AM
Anyone in Glasgow area or central Scotland got a complete Haynes Roadster chassis I can check fit of new Bonnet, Nose and Scuttle I'm currently producing new mould tools for? Will save me the hassle of building a chassis jig.........thanks
[Edited on 30/9/17 by Hugh Paterson]
Talon Motorsport - 30/9/17 at 09:52 AM
You only need 4 tubes to simulate the top of the chassis, top of front frame 627mm, each top rail 1472mm with 10' Z angles and a tube to keep them the correct distance apart at the back 1068mm with 10' angles each end.
Hugh Paterson - 1/10/17 at 08:52 AM
I know that thanks, used to build chassis and bodywork but 90% of my work is now marine (boatbuilder), just as easy to give someone complete prototype and try for size if they are next door Talon. No space for a chassis jig, boat mould and a new plug in the way till spring. Most of my body mould been in storage for 7 years now hence new tooling
Davg - 1/10/17 at 11:03 AM
MK chassis not too far from ya any help?
Hugh Paterson - 1/10/17 at 05:29 PM
Thanks Davg, will get back to you once I done some mods want to see how they look on complete car. Be a couple of weeks busy on larger jobs
