Author: Subject: Head lights
Dave Bailey
posted on 13/10/09 at 04:42 PM Reply With Quote
Head lights
I have made some headlight brackets and to cut a long story short I was a bit tight on the 500mm min to the ground. I can get the dimension but the lights tend to sit in between the Nose cone and the Cycle wing. This means that straight on you can see the lilghts but viewed from the side the far light will be covered by the nose cone... Will this be a problem for IVA?
thanks
Dave B
russbost
posted on 13/10/09 at 04:53 PM Reply With Quote
IIRC has to be visible from a 45 degree angle from the lens
Guinness
posted on 13/10/09 at 04:57 PM Reply With Quote
I think these are still current:-
From the old SVA manual
Light Angles
Light Angles
and
Light Angles Side
Light Angles Side
HTH
Mike
Dave Bailey
posted on 15/10/09 at 05:19 PM Reply With Quote
Need some help here to make sure I have read it correctly. The IVA manual seems to state 45 degrees outward and 10 degree inwards? Anyone know if this is whole surface visible or 50%?
thanks
Dave B
