Author: Subject: Indicator Height
Lightning
posted on 2/6/04 at 08:50 PM Reply With Quote
Indicator Height
My abridged version of SVA says the height of the front indicatoprs should be min 350mm.......What it doesn't say is , is that to the Centre line or the base?
If its to the base I will raise the height of the car by some 10mm to compensate.
posted on 2/6/04 at 09:24 PM Reply With Quote
I just looked at my unabridged version I read it as to the bottom of the illuminated bit.
Others may have a different opinion...
tractorboy
posted on 2/6/04 at 09:46 PM Reply With Quote
also be aware that they must be within 400mm of the edge of the car (measurement taken from the widest point of the car)
Lightning
posted on 2/6/04 at 10:05 PM Reply With Quote
Cheers. I thought it was to the bottom. Good job there is adjustable suspension.
spunky
posted on 3/6/04 at 08:29 AM Reply With Quote
Having fallen foul of SVA on this last week I can confirm that it is 350mm to the base of the illuminated area....
John
