<<  1    2    3  >>
Author: Subject: IVA Pics - IVA on tueday...
locostbuyer83
posted on 5/5/11 at 08:03 PM Reply With Quote
Hi Guys,
Please can you have a look at my build and let me know if you spot any IVA fail points.
IGNORE the holes in the scuttle. that's where my repeaters once were. will fill the holes before IVA
I also have a bonnet to put on obviously.
I also am going to get the tracking done tomorrow so have not yet covered the track rods.
franky
posted on 5/5/11 at 08:10 PM Reply With Quote
That looks nice
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 5/5/11 at 08:11 PM Reply With Quote
Adjusting nut at base of centre mirror may need covering.
Hows my exhaust,gas bottles and regulator
Gotta say thats looking pretty good though.
[Edited on 5/5/11 by CRAIGR]
Davegtst
posted on 5/5/11 at 08:22 PM Reply With Quote
Nose cone has no grille. Fog and reverse lights are on the wrong sides. Can you vent the engine breather to atmosphere via a filter? Thought it had to be recirculated. Looks very nice.
[Edited on 5/5/11 by Davegtst]
jack_t
posted on 5/5/11 at 08:25 PM Reply With Quote
-camber adjuster locknut needs covering
-not sure eyebolts on seatbelts are iva compliant either
-you need some 25-30mm pipe around under the spring collet on the front shocks as they have sharp edges
-reverse lever labeling?
-pipes from brake resivoir to cylinder need cabling to secure them more
-seems stupid but i had my foglight mounted like you and it wasnt mounted vertical and that was a fail
-you have taken the sierra wheel off if you have the horn piece for it so that its as you would see it in the sierra then put that back
on as it will defiantly pass as it is already on a production car
ReMan
very very nice
What colour is it?
It looks very tidy and well put together.
Is the fog light vertical?
Will it get a grill?
Wing Mirror mounts?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
Davedew
posted on 5/5/11 at 08:26 PM Reply With Quote
Firstly I must say what a nice looking car you have built.
A couple of things I have noticed. Do you have a grill to fit as they might pick up on some radius's possibly.
Secondly the fog and reverse lights are the wrong way round. The fog light has to central or on the offside of the car.
Hope that helps
Dave
locostbuyer83
posted on 5/5/11 at 08:31 PM Reply With Quote
Originally posted by ReMan
very very nice
What colour is it?
Wing Mirror mounts?
Grill = there is one, its just not clear in the photos ]
Wing mirror mounts? They are bolted to the fibreglass?
Its Kawasaki Racing green (metallic)
locostbuyer83
posted on 5/5/11 at 08:32 PM Reply With Quote
camber adjustment nut has self imalgimating_ tape around
pretty sure eye bolts are ok
thought the springs were exempt now?
locostbuyer83
Track rods = to be covered after tracking is done
engine breather = what should I do about that???
I will adjust the fog light to be vertical and swap them over - doh thats a mission!
ReMan
posted on 5/5/11 at 08:39 PM Reply With Quote
very very nice
What colour is it?
Wing Mirror mounts?
Cracking colour.
The wing mirror mounts may be close on the external radiusness
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
locostbuyer83
posted on 5/5/11 at 08:40 PM Reply With Quote
very very nice
What colour is it?
Wing Mirror mounts?
Cracking colour.
Yeah thought that today when fitting them, anyone got an idea on how to cover them?
Bigheppy
posted on 5/5/11 at 08:58 PM Reply With Quote
Rear exhaust mounting ?
rayward
posted on 5/5/11 at 09:08 PM Reply With Quote
dash warning lights ???
do they have the correct symbols on them, which the light shines through ?
if not you may need to change them
Ray
locostbuyer83
posted on 5/5/11 at 09:10 PM Reply With Quote
Ray
I have this for reverse
http://www.cbsonline.co.uk/product/LAMP_WARNING_LIGHT_GREEN_WLSLAMG
this for brake fluid
http://www.cbsonline.co.uk/product/SMALL_CHROME_BEZEL_BRAKE_WARNING_LIGHT_WLSBRK
and this for fog
http://www.cbsonline.co.uk/product/REAR_FOG_WARNING_LIGHT_AMBER_WLSRFA
I have a plain red light for the handbrake
That sound ok?
big-vee-twin
posted on 5/5/11 at 09:17 PM Reply With Quote
Is fog light vertical and you need a label on bias bar set up worded as in IVA manual
Think you need an oil catch tank too.
[Edited on 5/5/11 by big-vee-twin]
http://www.triangleltd.com
locostbuyer83
posted on 5/5/11 at 09:19 PM Reply With Quote
Do you mean my reverse lever? Don't have twin master cylinders.
big-vee-twin
posted on 5/5/11 at 09:21 PM Reply With Quote
No label needed then, looked like you may have two masters I stand corrected
God can't spell, that car looks just great though very nice
se7en
posted on 5/5/11 at 09:35 PM Reply With Quote
Hi
Your rear FOG and REVERSE lights are on the wrong sides.
Fog MUST be on the right and Reverse can be on any side.
HTH
Tom
Sorry Dave didn't see your post
[Edited on 5/5/11 by se7en]
ReMan
posted on 5/5/11 at 09:43 PM Reply With Quote
very very nice
What colour is it?
Wing Mirror mounts?
Cracking colour.
This sort of thing
http://www.getgeared.co.uk/Yamaha_YZF_R1_Motorcycle_Mirror
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
locostbuyer83
posted on 5/5/11 at 09:44 PM Reply With Quote
very very nice
What colour is it?
Wing Mirror mounts?
Cracking colour.
This sort of thing
My IVA is on tuesday. Need a quick fix.
ReMan
posted on 5/5/11 at 10:07 PM Reply With Quote
s/a tape wrap?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
locostbuyer83
posted on 6/5/11 at 06:24 AM Reply With Quote
Thanks for everyone's input. I'll crack on making those amendments today and repost tonight with new photos.
Like to get this passed on Tuesday
stevegough
posted on 6/5/11 at 07:12 AM Reply With Quote
You have done an absolutely cracking job, there - but you wanted some input...
Firstly, The volume inside the assumed planes of the two front wishbones is exempt from radius issues - your top mount of the coilover will need edging if it both falls outside of this virtual 'box' AND it can be contacted with the 100mm sphere.
Secondly - they will definitely frown on the temporary nature of the steering wheel crash - pad - put the sierra one back on for the test.
Third (and lastly) the Foglight will fail (as others have said) because its on the wrong side and it MUST be fitted on a vertical orientation. The fog lens is designed to concentrate the emitted light and throw a parrallel beam out - this has to be parrallel to the floor.
Other than that, check that safety - related bolts all have locking devices on them - usually nylocs, but tabs are used in some places. This applies to suspension bolts, steering column / rack / extensions, braking eg master cylinder mounts. My major fail point was where the steering column joined to the extension there was no locking device.
Best of luck for next week.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
locostbuyer83
posted on 6/5/11 at 07:33 AM Reply With Quote
Thanks for the input, I know the steering wheel cover is crap but the sierra one wont fit with my mk3 fiesta shroud. I'll order a IVA friendly steering wheel if thats whats needed?
<<  1    2    3  >>
