Author: Subject: Anyone passed an SVA with Dzus fasteners fitted ?
givemethebighammer
posted on 28/7/04 at 10:01 PM Reply With Quote
Did you need to cover them up or radius the edges ?
thanks
zetec
posted on 28/7/04 at 11:39 PM Reply With Quote
I had them fitted for SVA all OK. They should lie almost flat on the panel so excluded from radius check.
Good luck with fitting them, mine were a real pain. I ended up changing the front bonnet ones for over centre catches as they kept coming open. Probably due to poor workmanship on my part!
tractorboy
posted on 30/7/04 at 06:31 AM Reply With Quote
i passed the sva with a similar fastener on my bonnet and nose cone.i used "cam-locks " which externally lock identical .as said befor there is no external projection to have to radius.
Fozzie
posted on 31/7/04 at 12:43 AM Reply With Quote
Mine passed in June with Dzus fasteners
Agree with above, mine are flush. The external ones are on the 'boot' lid, no problems at all!
fozzie
givemethebighammer
posted on 31/7/04 at 11:35 PM Reply With Quote
I been putting this one off, guess I'll have a go this week. still sounds like a bitch of a job though.
thanks
MkIndy7
posted on 2/8/04 at 06:48 PM Reply With Quote
I second Zetecs experiences with the catches un-doing/lifting at speed. Ours lined up exactly level when locked yet they would ride up the spring they lock onto at 50+mph, to the point that you could see the front wishbones from the passenger seat! so we decided 2 change them just incase. They never came off but at the end of a journey they needed relocking again.
Xy
posted on 3/8/04 at 06:00 PM Reply With Quote
Whilst on the subject...
Could anyone recommend someone who could supply Stainless Dzus fasteners?
( I can only find the Zinc Plated ones..)
Matthew
tractorboy
posted on 3/8/04 at 07:18 PM Reply With Quote
deamon tweeks do them but they arent cheap.if its any help they are used in the aircraft industry(probably makes them more expensive still!) but may give you a new line of enquiery
scott
