Author: Subject: S2000 ECU and Throttle Bodies
Calzonii
posted on 20/9/15 at 10:04 AM Reply With Quote
S2000 throttle bodies and ECU. Preferably Emerald or Omex ecu and any throttle bodies. Jenvey omex.. Anyone know of anywhere to get these 2nd hand i imagine they are hard to get
Ugg10
posted on 20/9/15 at 10:37 AM Reply With Quote
Saw these on eBay they may do the job but I have not used them so others that have will have to vouch for how good/bad they are. But they look good value and available in different sizes.
4 Cylinder DCOE 50mm Throttle Body Kit inc TPS &' Ram Tubes - Performance &' Race
You will need to get someone like bogg bros od danst to make up a manifold though. And sort out injector ports etc.
Or these look good value as well.
Roller Barrel Throttle Bodies ITB (R500, kit car, DCOE, caterham)
As for ecu there is this
http://www.turbosport.co.uk/showthread.php?t=861008
Or a step up uf you need to go sequential
http://www.turbosport.co.uk/showthread.php?t=861543
[Edited on 20/9/15 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Calzonii
posted on 20/9/15 at 10:57 AM Reply With Quote
Thanks for all that info Ugg!
Ugg10
posted on 20/9/15 at 11:02 AM Reply With Quote
Also came across this ecu, started a thread on it, sone interesting features at a great price. Again no idea how well it works....
http://rrrshop.co.uk/ecumaster-emu-1-p.asp
daniel mason
posted on 20/9/15 at 12:33 PM Reply With Quote
Oem Ecu and throttle body will work fine if you put the time into sorting the loom
lukewillis1
posted on 27/9/15 at 08:16 PM Reply With Quote
throttle bodies and ecu
don't no if you will be interested but I have a set of danst engineering gsxr 1000 throttle bodies and manifold to suit zetec and also have dta e48 ecu for sale to suit with loom if your interested my number if interested 07528606907
thanks luke
Calzonii
posted on 27/9/15 at 10:33 PM Reply With Quote
Thanks Luke, will ring you tomorrow. If I dont et a chance my numbers 07549982326. Gimme a call whenever if you dont hear from me and we can discuss! Thanks.
Cal
