Author: Subject: Tunnel pumbing and wiring
Wolf1e
posted on 27/12/16 at 01:38 PM Reply With Quote
Hi guys
Can you run the wiring loom and fuel line the same side inside the tunnel? Was going to p-clip the fuel line and wiring loom seperatly like one under the other. Is this ok for iva or would they prefer the fuel and wiring to be on separate sides? Also can you run either fuel or wiring with the brake lines?
Just trying to get an idea which is correct and doesn't look a mess.
Cheers guys
Ian
[Edited on 27/12/16 by Wolf1e]
ian locostzx9rc2
posted on 27/12/16 at 02:54 PM Reply With Quote
If it was me I'll run the fuel and brake lines one side and wiring the other side .
big-vee-twin
posted on 27/12/16 at 06:29 PM Reply With Quote
Doesn't matter so long as everything is securely fixed at 300 mm centres and the pipe/ wiring doesn't rub on the chassis.
http://www.triangleltd.com
Toprivetguns
posted on 27/12/16 at 07:51 PM Reply With Quote
Also if not already planned use copper pipe or similar along the tunnel for the fuel line.
Saves the ache of changing a perishing rubber hose.
[Edited on 27/12/16 by Toprivetguns]
Only drive as fast as your angel can fly... !
Wolf1e
posted on 27/12/16 at 08:33 PM Reply With Quote
Thanks guys for input.
Toprivetguns: I am already going to run cooper pipe as was thinking the same ;-)
big-vee-twin: thank you :-)
I've already routed the brake lines so I'll route the wiring loom and fuel line the other side with the wiring loom the top one of the 2.
Ian
loggyboy
posted on 27/12/16 at 08:39 PM Reply With Quote
Use kunifer instead copper if you want long term peace of mind.
Mistral Motorsport
avagolen
posted on 27/12/16 at 08:48 PM Reply With Quote
This is my tunnel setup. Passed IVA without any comments.
P_clip_bracket
P_clip_bracket
Have fun.
