Author: Subject: Fog lights and MOT
r1_pete
posted on 24/4/17 at 04:37 PM Reply With Quote
Fog lights and MOT
I know there are a couple of MOT testers on here, if you could clear something up for me...
Im removing the front foglights on my 944 to tidy the front up, but the way the switching works means I will need to retain the front fog switch.
I understand if the lights are fitted they must work, but what if the switch is there but no lights?
Alternatively, as the car has pop up headlights, it has second main beam activated lights in the bumper, I could disconnect these from main beam, leaving just the two popup mains, and wire the bumper lights from the fog switch, would this meet MOT regs.
ian locostzx9rc2
posted on 24/4/17 at 04:45 PM Reply With Quote
Front fog lamps are not part of the mot
r1_pete
posted on 24/4/17 at 04:49 PM Reply With Quote
Cool, thank you, that makes things a bit easier.
chillis
posted on 24/4/17 at 07:01 PM Reply With Quote
Not strictly true. They are not mandatory lights but if they are fitted to the vehicle must they be working. If however you have removed them then they cannot fail.
Never under estimate the ingenuity of an idiot!
loggyboy
posted on 24/4/17 at 07:55 PM Reply With Quote
Not true.. they are not tested at all and cannot be a reason for failure.
Mistral Motorsport
posted on 24/4/17 at 08:02 PM Reply With Quote
My fiat has passed all its mot's in the 5 years I've had it with one front one not working...
907
posted on 25/4/17 at 05:27 AM Reply With Quote
But that is only to be expected from Italian electrics.
