Author: Subject: Pre sva pics (LOTS OF THEM)
graememk
posted on 7/4/07 at 03:11 PM Reply With Quote
Have a look and make a comment please, i'm covering up the bottom of the front shocks tomorrow.
graememksva1
graememksva1
graememksva2
graememksva2
graememksva3
graememksva3
graememksva4
graememksva4
graememksva5
graememksva5
graememksva6
graememksva6
graememksva7
graememksva7
graememksva8
graememksva8
[Edited on 7/4/07 by graememk]
stevec
posted on 7/4/07 at 03:19 PM Reply With Quote
I would take the fly screen off for the test,
Steve.
scutter
posted on 7/4/07 at 04:00 PM Reply With Quote
Looks good fella, I would cover the metal triangles for the upper harness mounts as i failed mine on them.
ATB Dan and good luck
nitram38
posted on 7/4/07 at 04:15 PM Reply With Quote
What are the radius on the gauges?
They look a bit "square" in the photos
graememk
posted on 7/4/07 at 04:21 PM Reply With Quote
there etb sva ok ones
westf27
posted on 7/4/07 at 04:27 PM Reply With Quote
rear view mirror
if you do take off the fly screen check the mirror base for radius
555
westf27
posted on 7/4/07 at 04:30 PM Reply With Quote
indicator side repeaters
do you need side repeaters couldnt see any
555
westf27
posted on 7/4/07 at 04:38 PM Reply With Quote
ally tunnel trim
trim joint by stick is that edge sharp
555
DRC INDY 7
posted on 7/4/07 at 05:13 PM Reply With Quote
I may be wrong here but i thought the harnesses had to be bolted in with 10.9 bolts and not clipped in eye bolts
plus the fly screen will have to come off unless you can radius the inner and outer edge simple to do
Puddle Dodgers Club
mookaloid
posted on 7/4/07 at 06:00 PM Reply With Quote
Your rear fog lamp must be totally vertical.
I had to make some adjustments to mine which looks just the same as yours.
The adjustable spring mounts at the front might need covering.
Same comments as above re fly screen, centre mirror and rear seat belt mounts.
Nice looking car though and good luck with the test
Mark
SeaBass
posted on 7/4/07 at 06:02 PM Reply With Quote
Indeed. Some test centres are asking for a marking on the eye bolt or certification. This seems fricking ridiculous. Howevere this applies only to certain test centres as is normal. Nothing like continuity eh??
Avoneer
posted on 7/4/07 at 07:17 PM Reply With Quote
You need to cover the rotating collar on the front shocks.
Pat...
shortie
posted on 7/4/07 at 07:22 PM Reply With Quote
Def take the screen off, less for him to check!!
Not sure about the eye bolts but personally if it was me I'd leave them and see if they mention it.
Apart from theta it looks pretty good to me, best advice is if you think an edge might be iffy then just cover it.
Car looks great, very smart and first impressions count alot imho.
Good luck,
Rich.
roadrunner
posted on 7/4/07 at 07:51 PM Reply With Quote
Hi Graham, mine passed ok with a deflecter screen just like yours, they sit some sort of measuring gauge on your seat, to see where the top of the screen should be.
Brad
Just look at my avatar.
[Edited on 7/4/07 by roadrunner]
scotty g
posted on 8/4/07 at 12:46 PM Reply With Quote
as Mark pointed out, some testers will fail the foam (is it pipe lagging?) that you have put over your threaded rack ends because it is held on with tie wraps, they regard this as being a temporary fixing which of course it is! If you wrap black insulation tape around it thay seem to happier with this, that amalgamating tape stuff is even better.
Bloody tidy job mate you should be very proud of that there car.
Cheers.
