Jesus-Ninja
posted on 15/10/08 at 04:39 PM |
Acceptable UJ angle in steering column.
What's the accepted limts for this? I have a 30deg "bend"
Suspension geometry tool here >>> http://www.locostbuilders.co.uk/viewthread.php?tid=81376
blakep82
posted on 15/10/08 at 05:22 PM |
you need to have two (if you don't have collapsable shafts or something) and i think (from memory) they should be angled at more than 10 or 15
degrees.
________________________
Flamez
posted on 15/10/08 at 05:39 PM |
Sect 14 of SVA states the greater the angle the more effective they will be at preventing movement being transmitted up the column.
It is unlikely that joints will work above 30 degrees and unlikely to be effective less than 10 degrees [ when viewed from side or top]
Therefore I deduce that between 10 and 30 is fine....
Jesus-Ninja
posted on 15/10/08 at 05:46 PM |
degrees.
Yeah, i have two, although the column between them is all of 8"! The one at the rack end is practically straight (maybe 5 deg), but the one
at the steering wheel end is the culprit.
Because of the angle of dangle of where the brake pedal is, this is the only way it all fits. Still, if 30deg is the limit, then I'll stick with
it as it is
Jesus-Ninja
posted on 15/10/08 at 05:47 PM |
Oh, and I do have a colapsable shaft Straight out of the saab donor
blakep82
posted on 15/10/08 at 06:40 PM |
if the shaft collapses, you don't really need to worry too much about the UJ angles, as long as the work and don't bind
Chippy
posted on 15/10/08 at 08:36 PM |
You will find that much over 20 deg's the UJ's dont work too well, and the steering will be hard to get it to "self centre".
HTH Ray
Jesus-Ninja
posted on 15/10/08 at 09:36 PM |
HTH Ray
Arse!
DarrenW
posted on 16/10/08 at 01:59 PM |
Depends on the specific UJ. They are designed with different operating angles. I dont recall seeing many designed to operate over 20degs.
