X Flow Gearbox
myke pocock - 30/8/12 at 05:57 PM
For those in the know, will this be OK to fit straight on to my 1300 x flow engine? I know that the gearstick is missing but does it look like the speedo take-off is also missing?
twybrow - 30/8/12 at 06:18 PM
I would say a photo or link is missing, let alone the speedo take off and gearstick!
myke pocock - 30/8/12 at 06:42 PM
What a plank!!! It's here.
Ford Pinto Type 9 Gear Box | eBay
RAYLEE29 - 30/8/12 at 06:55 PM
Hi, the speedo drive is on the righthand side of the box and looks intact to me.
This box should fit straight on with the appropriate sandwich plate and clutch.
Ray
rusty nuts - 30/8/12 at 07:02 PM
If you are changing from a 4 speed box don't forget the box is longer and may have different splines
spiderman - 30/8/12 at 07:25 PM
Speedo cable attaches with a circlip and that one looks fine.
everest - 31/8/12 at 11:34 AM
If your stuck , try the guys at BGH Geartech , Kent,: 01580 714114 , they are specialist in all things Ford gearbox , spares to full road / race rebuilds.
Hope this helps.
Chris
dave-69isit - 31/8/12 at 04:52 PM
why is the bolts out off the extension houseing
