Author: Subject: Gaz Shocks
mad_skillz
posted on 29/12/02 at 02:18 PM Reply With Quote
Gaz Shocks
I have bought a set (4) of adjustable gaz shocks but dont know what the spring rate is, they have black springs. Can any one help me? Also how do i adjust them ie to make them stiffer etc, there is a plus and minus toggle on the side and the springs can be screwed up and down?
Thanks very much
alex
Viper
posted on 29/12/02 at 02:43 PM Reply With Quote
Springs are usualy marked on the part of the coil that is ground flat should say the poundage and the free length. with dampening you usualy turn thr knob clockwise to increase damping or stiffness
nope this helps.
bob
posted on 29/12/02 at 10:02 PM Reply With Quote
Yep viper is right mine are marked on the flat on one end,325 and 175lb.
[Edited on 29/12/02 by bob]
Stu16v
posted on 29/12/02 at 11:50 PM Reply With Quote
And the adjustable spring platforms are to alter the ride height of your car.
HTH Stu.
