Author: Subject: Brake parts
Eggy
posted on 16/3/09 at 06:36 PM Reply With Quote
Brake parts
The saga of the brakes continue!!
First question: does anyone know where I can get some more of these (ideally would like the same rather than having a mix on the car)
Brake pipe clip
Brake pipe clip
Second question: I can't make sense of the measurement size of the brake pipe fittings - I need a blank/ plug/ bleed nipple/ brake light switch (something to plug up the spare hole in the m/c) - the larger of the two in the photo
Brake fittings
Brake fittings
Thanks in advance,
Kev.
mistergrumpy
posted on 16/3/09 at 06:40 PM Reply With Quote
For the blank on the MC I just used (yesterday) an M12 bleed nipple. It's a M12 1mm thread.
jacko
posted on 16/3/09 at 06:47 PM Reply With Quote
I hope the clips are tight or they will soon wear through the brake pipe
the clips with rubber in them would be better
For the other bits try a motor factors
ie motor world / waterloo /
thunderace
posted on 16/3/09 at 06:48 PM Reply With Quote
you cold look here
http://www.cbsonline.co.uk/index.asp
Eggy
posted on 16/3/09 at 07:15 PM Reply With Quote
Where did you get it from?
Eggy
posted on 16/3/09 at 07:17 PM Reply With Quote
They seem to be holding fine and tbh I quite like the "slim" look of them
mistergrumpy
posted on 16/3/09 at 07:22 PM Reply With Quote
Brakes international near mine. I'm back there tomorrow because I forgot to pick up an m10 one for the caliper too.
Have you put the Fiesta MC on yet? I did it yesterday. Bit of a pain. Holes not same as Sierra and pushrod is longer so had to be cut and welded.
posted on 16/3/09 at 07:41 PM Reply With Quote
Looks like an SVA & MOT fail to me especially with (shudder) copper brake lines.
You need to protect the pipe under the clip against chaffing with rubber or plastic tube, similar to the way the pipes were fitted accross the Escort rear axle.
Best way to clip brake pipes is OEM style plastic pop-in clips, second best are cushioned p-clips.
flak monkey
posted on 16/3/09 at 07:46 PM Reply With Quote
Brake pipes must not touch anything other than the clips they are in either. So if your pipes are laying on the chassis it will be a fail at SVA/IVA I am afraid.
I would suggest p-clipping them for ease.
Sera
http://www.motosera.com
Eggy
posted on 16/3/09 at 08:12 PM Reply With Quote
The mounting adaptor plate is being made as we speak, then the pedal to pushrod adaptor. Pipes are all done (or were until I've seen the other posts about them touching the chassis??)
mistergrumpy
posted on 16/3/09 at 08:16 PM Reply With Quote
Cool. Shouldn't take that long to redo the pipe clips. I've replaced my brake lines 3 times now I think!
Eggy
posted on 16/3/09 at 08:36 PM Reply With Quote
What pipe material does everyone else use? (If copper is that bad - seems ok to repair cars for MOT with?)
mistergrumpy
posted on 16/3/09 at 08:38 PM Reply With Quote
Kunifer/cunifer (sp) 3/16"
skidude88
posted on 26/3/09 at 07:19 PM Reply With Quote
blank-bleed nipple
I'm looking into doing the same. (blocking up spare front port)
I went to my local friendly garage\mechanic today to see if he had any bleed nipples to use as a plug.
(I'm replacing a 2 port willwood 1" tandem with a 3 port Fiat\Lada .75" )
He advised against this, saying the inner workings are designed so that each port gives even fluid pressure
, and suggested taking a feed from both front ports and then joining with a T and then connecting up to my existing line.
I appreciate brakes are important so if in double do it properly...ie run two separate lines.....
but I can't see any difference between the two scenarios,
I don't know the exact the inners of the M\cylinder and I'm not an expert on "fluid mechanics"
So thought I'd check with the forum - If anyone could explain?
cheers,
James.
Early MK de-Dion CBR1000 FJ-FP.
posted on 27/3/09 at 08:30 PM Reply With Quote
I went to my local friendly garagemechanic today to see if he had any bleed nipples to use as a plug.
(I'm replacing a 2 port willwood 1" tandem with a 3 port FiatLada .75" )
I don't know the exact the inners of the Mcylinder and I'm not an expert on "fluid mechanics"
cheers,
James.
What ever you do don't let that guy touch anything on any car you or any of your loved ones drive or are a pasenger in -----------
