Author: Subject: Clevis fixing
Jay k
posted on 15/4/09 at 01:32 PM Reply With Quote
Clevis fixing
I am trying to locate a clevis jaw with a m8 thread and with a 6mm pin, for the brake pushrod / pedal fixing.
Can anyone tell me where I can buy one from?
Thanks in advance
Jay K
Keith Weiland
posted on 15/4/09 at 01:59 PM Reply With Quote
Is this any good?
http://www.cbsonline.co.uk/master-cylinder-clevis-clevis-130-p.asp
Jay k
posted on 15/4/09 at 02:17 PM Reply With Quote
Not quite - it has the wrong thread. I need m8
posted on 15/4/09 at 02:18 PM Reply With Quote
Rally Design sell the clevis pi with 8 mm thread. I used one for brake master screw on to end of M8 bolt with head cut off.
I cannot recall what the diameter of the hole was but I think it was 8 mm - you can alwasy sleeve the hole with tube - B&Q do steel tube 8 mm 10 mm etc, all about 1 mm wal thickness. If you get stuck, I can post you a short bit of 8 mm OD tube (pretty sure I should have some about)
Jay k
posted on 15/4/09 at 02:21 PM Reply With Quote
The hole in the pedal is 6mm and I do not want to enlarge, so ideally need the m8 thread with 6mm pin
posted on 15/4/09 at 02:43 PM Reply With Quote
^^^ or sleeve the pin to match the 8 mm hole.
Jay k
posted on 15/4/09 at 02:46 PM Reply With Quote
I haven't got an 8mm hole ??? It's 6mm
Cousin Cleotis
posted on 15/4/09 at 05:46 PM Reply With Quote
Why cant you drill the hole to 8mm? 6mm sounds small for a brake clevis, most are 8mm.
Paul
[Edited on 15/4/09 by Cousin Cleotis]
Jay k
posted on 16/4/09 at 07:40 AM Reply With Quote
Here is a pic of the brake pedal, as you will see the hole indicated is for the clevis. The bigger the hole the less metal there will beteewn the 2 holes.
pedals
pedals
[Edited on 16/4/09 by Jay k]
