Author: Subject: torque figure for sierra hub nut???
INDY BIRD
posted on 7/11/09 at 09:36 AM Reply With Quote
Hi all
putting my sierra hubs back toigether but have no manual can anyone tell me what torque figure i need for the sierra hub nuts
thanks all
posted on 7/11/09 at 09:43 AM Reply With Quote
I'm sure recently there was a discussion re where the find the haynes sierra manual online....
JekRankin
posted on 7/11/09 at 09:45 AM Reply With Quote
INDY BIRD you have u2u :-)
Frosty
posted on 7/11/09 at 10:42 AM Reply With Quote
340Nm or 250 lb/ft
wilkingj
posted on 7/11/09 at 11:54 AM Reply With Quote
Originally posted by Frosty
340Nm or 250 lb/ft
Yup... I was going to say it was 240Ft Lbs.. Its a tight Bugger. And Its a 41mm socket from memory.
Also be aware one is Right Hand and the other is left hand thread.
So make sure you put the shafts on the correct sides, or the nuts might come undone. Which is not a good experience. I've been there with a Caravan that lost a wheel doing 45mph in Bank Holiday traffic... many years ago and its not nice!
I made this up to undo and do my nuts up nice and tight.
Are your Nuts Too Tight?
Best Regards
Geoff
http://www.v8viento.co.uk
INDY BIRD
posted on 7/11/09 at 07:09 PM Reply With Quote
yep thanks for the tips.
i persume as long as they both do up towards the front/undo towards the rear they would both be correct???
thanks again
