New Topic New Reply
Author: Subject: Master cylinder pushrod question
Jay k
posted on 29/1/10 at 12:06 PM Reply With Quote
Fitted the brake pedal last night and wasn't sure how long the push rod should be, as when the pedal is pressed in fully - should you feel the push rod bottom out, so the master cylinder cannot be pushed in any further or is there an approximate measurement that the cylinder should be pushed in?
Thanks in advance
Jamie
Jay k
posted on 29/1/10 at 12:09 PM Reply With Quote
Sierra master cylinder fitted if needed to know
r1_pete
posted on 29/1/10 at 12:10 PM Reply With Quote
More important the rod should be short enough to allow the piston to uncover the hole which allows fluid to flow into the cylinder.
Otherwise as your pads wear the pedal travel will get longer and longer.
blakep82
posted on 29/1/10 at 12:17 PM Reply With Quote
are you pushing the pedal down now with no fluid in it i assume?
when its filled up the pressure in the system shouldn't allow the cylinder to bottom out.
________________________
Jay k
posted on 29/1/10 at 12:18 PM Reply With Quote
Sorry must have my stupid head on - as I'm lost with that !!
With my pedal at rest, the piston returns all the way and there is no free play in the pedal- but when I go to full pedal depression should the piston go fully in so it can go no further?
Jay k
posted on 29/1/10 at 12:20 PM Reply With Quote
blakep82 - Sorry posted just after you.
Yep no fluid in so that would make sense.
Will get the fluid into tonight and have a play.
Many thanks
blakep82
posted on 29/1/10 at 12:24 PM Reply With Quote
yeah, with no fluid in, the only limiting factors would be if the pedal hits the bulkhead, or the piston reaches full travel. if its filled with fluid, brake pad wear, and pressure in the system them come into it.
if its filled with fluid and still happens, then you have other problems
New Topic New Reply
