Author: Subject: Master Cylinder fittings
posted on 17/3/10 at 12:18 AM Reply With Quote
I have acquired a new master cylinder that I've been told is for an old Nissan pickup with drum brakes. The bore is 19mm, so should be good for the non-servo use on my Striker. However, I'm a bit puzzled about the fittings:
Nissan Master Cylinder
One port has a very deep thread (~16mm) with no seat. I'm guessing a banjo bolt and sealing washers would have been used here? It also seems to have some kind of valve at the bottom that appears to function like a residual pressure valve.
Master cylinder fitting 2
The other port has a short thread (~8-9mm), with a reverse tapered seat at the bottom. Can I put a double flare on a pipe and (safely) use it with a conventional tube nut?
I think the thread is 3/8 UNF, it's certainly too coarse to be M10 * 1.0. In all other respects this fit my pedalbox perfectly, so would like to use it if possible,
indykid
posted on 17/3/10 at 12:45 AM Reply With Quote
looks like a banjo fittinga nd a double flare to me, similar to an mx5.
all the mx5 fittings are like that with the convex seat and double flared. all my flares i made at the rear have sealed and stayed sealed.
could the fittings be m10x1.25? can't imagine nissan would use imperial, even in the days of yore
tom
posted on 17/3/10 at 01:00 AM Reply With Quote
tom
Could well be M10x1.25 now you mention it, but I didn't realise that size was ever used on brakes! Sounds like I can probably use it then, good news.
russbost
posted on 17/3/10 at 09:19 AM Reply With Quote
3/8 & m10 x 1.0 are almost indistinguishable, you can actually screw a 3/8 male into a m10 x 1.0 female (tho' I wouldn't recommend it)
M10 x 1.25 is very commonly used on Jap motorbikes tho' only ever seen it on cars on old Fiats & their derivatives like Lada,FSO etc
The deep hole would be a banjo fitting, the others take a standard double flare (OP2)
posted on 17/3/10 at 10:22 AM Reply With Quote
In that case it's definitely not 3/8 since the thread pitch is visibly coarser than an M10x1.0 banjo bolt I tried in it. Somewhere I have a Metric thread gauge, but darned if I could find it last night.
Seems like banjo bolts are fairly easily available in M10 x 1.25, but the fittings for solid brake pipe don't seem very common.
[Edited on 17/3/10 by MikeRJ]
iank
posted on 17/3/10 at 11:20 AM Reply With Quote
Rally Design stock them
http://www.rallydesign.co.uk/product_info.php?cPath=85_1923_1210&products_id=9955
Anonymous
whitestu
I'm fairly sure my Fiat MC needed m10 x 1.25. I managed to get hold of some easy enough, but can't remember where from!
Stu
posted on 17/3/10 at 11:52 AM Reply With Quote
I ordered a bunch of stuff from RD a couple of days ago, how typical
Bluemoon
posted on 17/3/10 at 12:27 PM Reply With Quote
Talk to them on the phone, bet you will get cheaper postage (than on-line)...
Dan
posted on 18/3/10 at 11:22 PM Reply With Quote
Thanks for the help chaps, I discovered my tap and die set had an M10x1.25 tap and it fits perfectly. I've ordered a banjo bolt, banjo adapter and a couple of M10x1.25 male brake fittings so I should be ready to work on the car during the lovely weather we are surely going to get at Easter
