Author: Subject: fitting rear disks?
-matt
posted on 19/6/10 at 09:28 AM Reply With Quote
fitting rear disks?
just a quick question,
if i get a donor sierra which has rear drums.
can i then just buy some rear callipers/carriers, or will i need different hubs Etc aswell?
cheers
big-vee-twin
posted on 19/6/10 at 10:19 AM Reply With Quote
You can buy brackets for the conversion from 3GE Components and use the same bearing carriers.
The drive flange will need turning down to 134mm to fit inside the disc bell and then you can fit new sierra calipers. see below:
Rear Caliper Bracket
Rear Brake mods
Rear Brake mods
http://www.triangleltd.com
