Author: Subject: Wilwood Bleed Nipples (again)
big-vee-twin
posted on 24/4/11 at 12:18 PM Reply With Quote
Some of you will have seen my previous post about breaking the Wilwood nipples.
After that Debarcle got everything sorted, I replaced the broken nipple with a standard Stainless Steel nipple which works fine.
Noticed this morning that all the Wilwood brass/steel nipples are weeping no matter how I tighten them, the replacement is not.
Question is how many of you guys have replaced your Wilwood brass inserts due to poor sealing and would it be ok to replace with stainless one's
Will stainless react with the aluminium caliper body?
http://www.triangleltd.com
bob tatt
posted on 24/4/11 at 02:15 PM Reply With Quote
had mine on three years now never had any issues with leaking at all.
posted on 24/4/11 at 03:36 PM Reply With Quote
Some Lock "n" Seal on the threads
tomgregory2000
posted on 24/4/11 at 04:27 PM Reply With Quote
brass and alloy is one of the worst combinations ever
stainless and alloy is much better
henryc
posted on 24/4/11 at 04:38 PM Reply With Quote
Glad I'm not the only one to have broken those stupidly small aliminium bleed nipples - did the manufacturer ever try and use them themselves? Annoys me to have something so simple be so rubbish. Did you replace the whole lot or just the aluminium part?
Henry.
big-vee-twin
posted on 24/4/11 at 04:50 PM Reply With Quote
I replaced the broken one with a single piece stainless one which seems to work much better, think I will swap them all.
For those of you who didn't see it here is the broken nipple
[img] Bleed nipple near disaster
[/img]
Johneturbo
posted on 24/4/11 at 06:04 PM Reply With Quote
when i first built the car and fitted them new from rally design they leaked straight away after bleeding them.
they sent me free replacements which were fine, but recently i had to disconect the flexi so had to re bleed one and it leaked
some ptfe tape seems to have cured it, i was really careful not to over tighten it.
PeteS2k
posted on 24/4/11 at 06:20 PM Reply With Quote
What thread is the Wilwood brass bit, and what stainless part do you use as replacement? Just so I know if and when mine go!
big-vee-twin
posted on 24/4/11 at 09:52 PM Reply With Quote
They are M10 x 1.0
Here's the replacement Wezmoto Stainless Steel Bleed Nipple M10 x 1.00 Single on eBay (end time 22-May-11 16:25:54 BST)
[Edited on 24/4/11 by big-vee-twin]
