Author: Subject: english diff rebuild
kehale
posted on 28/11/11 at 10:32 PM Reply With Quote
CAN ANYONE GIVE ANY INFO REBUILDING ENGLISH DIFF,PURCHASED REBUILD KIT,ANY GOOD BOOKS,OR ONLINE INFO THANKS
twybrow
posted on 28/11/11 at 11:02 PM Reply With Quote
Unless you are familiar with them, I would say you might be better to let a pro rebuild it for you... Getting the backlash set correctly is rather tricky...
I took mine to Procomp. For £200 they rebuilt it with my Quaife LSD, and set it up for the car. Money well spent IMHO.
If you want to do it yourself, check out the Haynes for the Mk2 escort - there is plenty of info in their on how to rebuild and setup.
snowy2
posted on 29/11/11 at 08:03 PM Reply With Quote
rebuilding a diff looks easy to do.....looks easy. it is actually very easy to get wrong and they are very fussy about how they are put together, it doesn't have to be far out to trash the diff in very short order. best left to those who know (and are properly tooled up for it)
sometimes you are the pigeon, most of the time the statue.
Confused but excited.
posted on 29/11/11 at 08:50 PM Reply With Quote
IIRC someone on the bay does a complete re-build, including parts for £120ish, for a std English axle.
procomp
posted on 30/11/11 at 11:21 AM Reply With Quote
Hi
Our prices for a rebuild start from £120. The others are just charging what we do. Difference is we use high quality bearings and parts and the fitment of a solid spacer is STD issue.
Cheers Matt
snowy2
posted on 30/11/11 at 03:57 PM Reply With Quote
You just may be hearing from me procomp i had the input bearing break up on my 3.54 diff last year on my way to south france noisy screetch and it went straight in to side of road before it got expensive. the crown and pinion look ok for reuse but the 3.89 i use now is a little lowly geared for touring.
[Edited on 30/11/11 by snowy2]
Rob Allison
posted on 30/11/11 at 07:27 PM Reply With Quote
Solid spacer is a must. I've done 3 diffs. Each breaking teeth for no reason i could tell. Until i was told about the cruch spacer
ShaunB
posted on 2/12/11 at 12:19 AM Reply With Quote
How much play is normal in an Escort axle (Salisbury if it makes a difference). I reckon I have 10 degrees play wheel to wheel and about 5 degrees on the prop input. One of the shaft seals is leaking so I'll be taking them both shafts out to check and while they are out...
Shaun.
