Author: Subject: What's this axle bracket for?
TimC
posted on 19/7/12 at 09:33 PM Reply With Quote
Thanks,
Tim
owelly
posted on 19/7/12 at 09:50 PM Reply With Quote
Brake pipe flexi mounting?
http://www.ppcmag.co.uk
bi22le
posted on 19/7/12 at 10:55 PM Reply With Quote
That was my first guess. Is there one on the other side?
Please read my ring story:
clairetoo
posted on 19/7/12 at 11:10 PM Reply With Quote
If thats an English axle (Mk2 Escort) then , no , there wont as the flexi goes to rigid pipe , then to the wheel cylinder on one side - then rigid pipe across the axle to the other wheel .
Its cuz I is blond , innit
Claire xx
Will weld for food......
Surrey Dave
posted on 19/7/12 at 11:37 PM Reply With Quote
eh!
If it's not brake flexi pipe mount it could be for a metal rod balance/compensator arrangement that connects the 2 handbrake operating levers to one cable.
spiderman
posted on 20/7/12 at 12:02 AM Reply With Quote
It is for the brake pipe flexi from the transmission tunnel and connects to a rigid pipe that goes to the offside wheel cylinder which is then connected to the nearside wheel cylinder via another rigid pipe. At least that's what it says in my Haynes manual for a MK1 Escort. Axle is pictured upside down.
Spider
dray13dad
posted on 20/7/12 at 04:58 AM Reply With Quote
+1
Surrey Dave
posted on 20/7/12 at 09:13 AM Reply With Quote
[img] Description
[/img]
posted on 20/7/12 at 10:08 AM Reply With Quote
Handbrake solid rod holder?
posted on 20/7/12 at 11:50 AM Reply With Quote
The handbrake is on the back, it's the flex pipe union bracket as above. Cut it off and weld an M6 bolt on top of the diff housing and use a T piece with a pipe to each wheel.
