Author: Subject: Rear Diff
Blade
posted on 20/9/02 at 07:15 PM Reply With Quote
Rear Diff
Whats the best choice for rear diff?
We're using a Fireblade engine and have been told that we really need a limited slip and also that the best gearing for these engines is around 3.36:1
I've got a standard seirra diff which is 3.62:1 and not limited slip.
I've seen a re-con diff thats 3.36:1 but its not limited Slip.
I can get hold of cossie parts fairly easily but dispite being limited slip they are 3.64 (2wd) and 3.62 (4wd).
What do I go for without spending a fortune on a Quaffe?
What have others used?
interestedparty
posted on 20/9/02 at 08:37 PM Reply With Quote
The diff is either limited slip or not, but it is the crownwheel and pinion that set the overall ratio. You need to speak to a specialist rebuilder about the possibility of combining the parts you have got and can get to produce what you want.
Westfeild people use-
Phil Stewart at Road & Race Transmissions on 01959 525105 based nr Sevenoaks in Kent
John
interestedparty
posted on 21/9/02 at 07:52 AM Reply With Quote
just spotted an advert for diff and lsd doings for westfeild etc in Kit Car no name given just a number 01380 812969 (Devizes Wiltshire)
