Author: Subject: Prop to Diff bolts
mikeb
posted on 6/12/12 at 03:25 PM Reply With Quote
Prop to Diff bolts
Does anyone know the spec for prop to diff bolts for the standard sierra diff.
Or even better if anyone has some knocking around for beer tokens?
Mike
renetom
posted on 6/12/12 at 03:42 PM Reply With Quote
bolts
Hi
Got mine from our local Ford main dealer
Not expensive , as you can see from the pict
they are 10.9.
Prop bolts Sierra
Prop bolts Sierra
Good luck
René.
mookaloid
posted on 6/12/12 at 03:44 PM Reply With Quote
Originally posted by renetom
Hi
they are 10.9.
Prop bolts Sierra
Prop bolts Sierra
Good luck
René.
Not sure but something in the back of my mind makes me think you are not supposed to use washers with those
big-vee-twin
posted on 6/12/12 at 03:48 PM Reply With Quote
Just use threadlock.
You can get them from Burton Power
http://www.triangleltd.com
rdodger
posted on 6/12/12 at 04:27 PM Reply With Quote
FORD PROP SHAFT DIFF BOLTS HIGH TENSILE SIERRA CORTINA
ebay is you friend..... sometimes
wylliezx9r
posted on 6/12/12 at 04:42 PM Reply With Quote
Hi
they are 10.9.
Prop bolts Sierra
Prop bolts Sierra
Good luck
René.
That's correct definitely not supposed to use washers.
George Best
renetom
posted on 6/12/12 at 05:02 PM Reply With Quote
Hi
they are 10.9.
Prop bolts Sierra
Prop bolts Sierra
Good luck
René.
Shakeproofs & locktite,
Belt & braces.
Been doing it on props since the sixty's not had one come off yet.
Don't care like anything.
bodger
posted on 6/12/12 at 05:03 PM Reply With Quote
Hi
they are 10.9.
Prop bolts Sierra
Prop bolts Sierra
Good luck
René.
What's the reasoning behind that?
rdodger
posted on 6/12/12 at 05:05 PM Reply With Quote
The back face has machined grooves in it to help it lock.
renetom
posted on 6/12/12 at 05:35 PM Reply With Quote
bolts
The ones I got were genuine Ford ones as per their computer spares layout
They had no grooves machined on the back & are 10.9 tensile not 12.9 as stated on you fleabay
lookalikes, you can have too much tensile strength which in certain applications
Can have a detrimental effect.
The end.
rdodger
posted on 6/12/12 at 05:55 PM Reply With Quote
In that case New Propshaft to Diff Flange Bolts: Escort Mk2, Capri, Sierra, Granada
I'm not using either. I found some spare flywheel bolts I had fitted perfectly. A blob of loctite and happy days.
[Edited on 6/12/12 by rdodger]
mcerd1
posted on 6/12/12 at 09:13 PM Reply With Quote
I think I've got a spare set - can post them at the weekend
