Author: Subject: suspension brackets
willie-7
posted on 27/9/02 at 10:33 PM Reply With Quote
suspension brackets
Hi guys,
Any one know a cheap source for the suspension brackets,as not had much success making them.
also can you buy the (L) part's for the front of the chassis,made up or pre cut and weld your self
thanks
willie-7
UncleFista
posted on 27/9/02 at 11:58 PM Reply With Quote
See Merlin for brackets, he also makes the "magic box" which does away with the need for the "L" construction
See the photo archive, under Merlin
HTH
Tony Bond / UncleFista
willie-7
posted on 28/9/02 at 08:35 AM Reply With Quote
Thanks UncleFista,
Just off to look at the site now.
Hornet
posted on 28/9/02 at 08:55 AM Reply With Quote
hi peeps, The best price for brakets i have seen is http://www.gtscougar.freeserve.co.uk/
£1.20 each
UncleFista
posted on 28/9/02 at 09:17 AM Reply With Quote
You can't have looked very far then
Dunc (check the photo archive) did me a full set for £20 inc postage
willie-7
posted on 28/9/02 at 09:44 AM Reply With Quote
Hi Hornet,
Tried them, but out of stock of the "book locost" brackets.
UncleFista
Any idea if dunc still sells them and how to get in touch with him.
thanks to all
willie
UncleFista
posted on 28/9/02 at 10:20 PM Reply With Quote
You could try sending him a U2U (private message) if you don't see anything of him, my set of brackets are just sat there doing nothing (seeing as I was supplied a set by MK when I got my suspension parts from him) give me a mail if you can't get in touch with him.
stephen_gusterson
posted on 28/9/02 at 11:57 PM Reply With Quote
the other way is to get a length of RHS 50mm square with 3mm side wall and cut one wall out....instant bracket.
atb
steve
theconrodkid
posted on 29/9/02 at 07:34 AM Reply With Quote
hardly instant brackets,gave up on that one same as the fuel tank,they were the only bits i gave up on though,try merlin he has some in stock
bob
posted on 29/9/02 at 08:13 AM Reply With Quote
If you want to contact merlin use the u2u on here as merlins e-mail is broke.
Parts i have from merlin are top drawer,look on his archive.
He will make a chassis too,your spec as well.
willie-7
posted on 29/9/02 at 08:23 AM Reply With Quote
Hi All,
Thanks for the advice,trying to follow it all up now.
willie
Hornet
posted on 29/9/02 at 08:29 AM Reply With Quote
Dunc only had a few left way back then m8
So as i said cheapest i have seen is £1.20
Unless u wana sell urs to me Unclefista as i need a set reet now?
stephen_gusterson
posted on 29/9/02 at 11:16 AM Reply With Quote
having spent 30 plus hrs making up the back of my car, and being half way through building a shed extension so i can have room to work, cutting one side off an rhs and drilling a couple holes seems pretty instant!
Of course if you can get em made, then great. But then push that too far and its not exactly the build from scratch concept anymore.
Agree about the fuel tank - trying to weld good enought to keep a searching solvent in (petrol) seemed like an expert job to me. SO i got mine made by my dad put of 1mm stainless.
atb
steve
