Author: Subject: Fisher Fury 2.0 Zetec Nodiz Bike Carbs First proper Start !
ragindave
posted on 16/10/13 at 03:04 PM Reply With Quote
Well it runs!
1993 2.0 Zetec
It didnít start on the first try as I had some wires crossed..
A couple of water leaks to sort out!
Water pump possibly going the wrong way round!
Very impressed with Nodiz Next job get Temperature sensor wired in and blu tooth to my phone..
Then balance the carbs.
Then really annoy the neighbours with some totally unnecessary revving of the engine..
http://youtu.be/4dDQMxfODRM
Dave Bailey
posted on 16/10/13 at 05:31 PM Reply With Quote
Nice one... sounds better than mine after a £400 rolling road setup! :-)
clanger
posted on 16/10/13 at 06:00 PM Reply With Quote
sweet...........
had a zetec with over the top of the manifold water rail like that, no end of problems and air locks..........i'd get it under the manifold...................should be ok if you keep the header tank on top of the bonnet like in the vid though
BaileyPerformance
posted on 16/10/13 at 06:26 PM Reply With Quote
Nice one!!
Can we offer to set it up for you? £250
Www.baileyperformance.co.uk
Dave Bailey
posted on 16/10/13 at 06:59 PM Reply With Quote
you can offer to set mine up! DTA S60 on an ST170 currently sequential and cam disabled but I would like to get them working properly.... At the moment I have Jenvey 48's on short trumpets so would take advice if the thoughts are that I should go for 45's first!
Plus we have the same name!
Dave B
BaileyPerformance
posted on 16/10/13 at 07:11 PM Reply With Quote
Dave B
That's a good name your've got there!! Bailey is just my company name, worked at ICS Bailey (first job) so borrowed the name.
No problem to setup your car, same price, not done the later DTA - have you got the software and cable?
Dave Bailey
posted on 16/10/13 at 07:31 PM Reply With Quote
I have a cable but I don't have the fuelling box for live mapping.... I know you have to start somewhere but I paid 450 for a setup and it doesn't run we'll low down... The sequential was set up wrong and the closed loop lambda needs setting up... Variable cam switches but it doesn't control correctly .. Pid needs setting up etc etc.... There are so many variables I think you need to know the ECU well to get it sorted.... What do you think?
Dave B
Andybarbet
posted on 16/10/13 at 08:27 PM Reply With Quote
Engine sounds great - do you have any info on your alternator mount, im trying to fit mine in exactly the same spot, just wondered what your mount looked like.
Cheers - Andy
BaileyPerformance
posted on 16/10/13 at 10:17 PM Reply With Quote
Dave B
It's no prob to get it sorted 100%, I have mapped all sorts of aftermarket Ecu's.
You do not need the live box to map it, it's just quicker to have fuel and advance on rotary controls than just using the laptop keys.
Please could you send me a pic if your throttle body setup? The not running well down low mite not be anything to do with the Ecu, sequential injection is not required and will make little difference - can actually make things worse.
Normally, Jenvey 45s with decent injectors and megasquirt the engine will take full throttle at 1000rpm full load and pull clean to red line, your 48s will make little difference to drivability but may give a few more bhp up top.
The variable cam timing is worth a chunk of power, assuming the cam sensor is working (as well as crank) it should be straightforward to setup.
Closed loop control should be setup to trim the fuelling at part throttle only, any decent load it should go open loop. Running closed loop only really helps mpg and won't effect drivability.
Dave Bailey
posted on 17/10/13 at 06:03 PM Reply With Quote
Well seems like you are keen which is a huge bonus.... Cam sensor works as does the cam advance valve but the cam position swings a lot...ie. not very stable with the current settings...
I have an innovate wide bad sensor... Best I send you some pictures of the setup, the current map if you want to download DTA software for S60 and a video of it running at the moment.....
Can you confirm an email address?
Dave B
ragindave
posted on 17/10/13 at 07:13 PM Reply With Quote
Rad switch knackered! That was a close call didnít boil up but was getting close.
Dropped the cooling pipes below the exhaust and fitted another new Rad switch both switches tested in a saucepan!!!!
Andy I will sort out a picture of the alternator mount it was supplied by Fisher Sports cars.
maccmike
posted on 17/10/13 at 07:22 PM Reply With Quote
quality looking workmanship there
BaileyPerformance
posted on 17/10/13 at 07:27 PM Reply With Quote
Dave B
dale.bladen@orange.net
No prob about the wide bad, I use my own NGK wide band and controller for mapping, we can get your sensor working later.
Andybarbet
posted on 17/10/13 at 11:24 PM Reply With Quote
That'd be great thanks - no rush though.
mtechmatt
posted on 18/10/13 at 09:24 AM Reply With Quote
Great to see you up and running!
Have linked you over on our youtube channel
http://www.youtube.com/user/themtechzone?feature=watch
Matt
V4 Engine Management System | Online Shop | Rolling Road Tuning | Motorsport Preparation | Engine Packages | Throttle Bodies
Check out what's happening in the workshop via our Facebook Page:
The Workshop
MEGASQUIRT ROLLING ROAD & BIKE CARB TUNING SPECIALISTS
www.mtechautomotive.co.uk
mtechmatt
Matt
The Workshop
