Nick Skidmore
posted on 8/12/13 at 09:58 PM |
Hayabusa tuning parts and 6pt harness
Available here before being fed to ebay.
Turbo plenum, integral bell mouth outlet stubs, four injector bosses in lid and tapped bosses for MAP sensor / pressure feeds. Polished and Anodised
black, unused £100
8 Bosch injectors, 4 used and 4 new? in boxes. 0 280 156 012 which on a search seem to be specced at 412 cc/min @ 3 bar and 14mm O ring top and
bottom. These will be Methanol compatible. £100
Heavy duty starter motor gear, not slipping clutch type but has wide gear in contact with the starter pinion. Micro polished / tumbled finish. New and
unused £50.
Raceparts / Securon 6pt single seater harness, black, 8mm holes in mounting plates. Out of date for FIA in a few weeks but OK for speed stuff. Has
generous length shoulder straps so would suit 'the fuller figure'. Used but unmarked. £30.
Also a Ralt RT3 roller, early spec if you're stuck with what to have for Xmas £12.5k
07903 474191, PM or nicktheskid@hotmail.co.uk
carpmart
posted on 8/12/13 at 11:26 PM |
Interested in the harness please. Aircraft coupler? 3 inch belts apart from groin area? 8mm holes suggests bolt in, is that correct?
Have you a pic you could share please?
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
Nick Skidmore
posted on 10/12/13 at 02:48 PM |
harness, injectors and plenum gone.
[Edited on 10/12/13 by Nick Skidmore]
