Author: Subject: Zetec on bike carbs - Omex or Megajolt?
matto_89
posted on 2/6/14 at 08:56 PM Reply With Quote
Hi All
Thinking of converting a seven from a X-Flow to a Zetec. Well trodden path I know, loads of good material out there. The Xflow is on bike carbs, and I want to go down the same route for the Zetec. For the spark, what's are the differences and pros/cons of each? My impression is that the omen is easier and more complete, but also more expensive - that fair? Will I need TPS for both?
austin man
posted on 2/6/14 at 09:10 PM Reply With Quote
Im running mine on megajolt with zx9 carbs
Ugg10
posted on 2/6/14 at 09:20 PM Reply With Quote
Have a look at nodiz, I had a fisher fury running a 2.0l silvertop on a chester sports cars bike carbs (zx6 I think) and megajolt jnr kit, ran really well. Chester have recently gone over to nodoz I think they may have been finding it difficult to source edis modules. Worth a search on both. You will need either a tps or a map sensor, most go for just the tps, you should be able to use the one that comes with the bike carbs.
[Edited on 2/6/14 by Ugg10]
luke2152
posted on 3/6/14 at 07:23 AM Reply With Quote
If you're going zetec, why not use bike thottle bodies instead of carbs and go injected
whitestu
posted on 3/6/14 at 07:39 AM Reply With Quote
I've got a Megajolt and been happy with it. It works well enough and is easy to change the map.
I use the TPS on my ZX6 carbs.
Stu
posted on 3/6/14 at 01:18 PM Reply With Quote
If I was doing it again i would use the ZX9 carbs with tps and a Megajolt.
Having tried injection I think I would rather spend some of the money on cams and better gearbox ratios and use the rest for a Caribbean holiday...
luke2152
posted on 3/6/14 at 01:49 PM Reply With Quote
Doesn't need to be expensive-especially since zetec already has fuel rail and injectors
Carbs+megajolt vs Throttle bods + megasquirt + fuelpump + couple of sensors
But I guess its all a personal preferance thing
alfas
posted on 3/6/14 at 05:54 PM Reply With Quote
is your x/flow up for sale?
if yes please sent me a PM with the spec. and condition.
thanks
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 3/6/14 at 09:51 PM Reply With Quote
I use Megajolt with my Zetec powered Royale single seater, using R1 carbs and Map. I have just spent 2 weeks in France hill climbing and received an incredible amount of comment about how much torque the motor has............
matto_89
posted on 3/6/14 at 10:40 PM Reply With Quote
Interesting on the megajolt, how did you map - yourself, or someone else for you?
Another option appears to be Nodiz. Less around on it, but the unit itself appears to have more stuff inbuilt than MJ.
The Xflow will probably be up for sale at some point later this year - 1700cc, 1300 cams, polished head, BCF2 cams, bike carbs and manifold from BB are the highlights.
whitestu
posted on 4/6/14 at 07:40 AM Reply With Quote
I just used someone else's map and tweaked it. No idea how much power it makes but it runs really well.
FASTdan
posted on 4/6/14 at 07:42 AM Reply With Quote
The NODIZ offers the best value for money and functionality and being a Zetec the map is readily available.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
mcerd1
posted on 4/6/14 at 08:09 AM Reply With Quote
Nodiz is quite new, its a standalone system so doesn't need the EDIS4 (which are getting a little harder to find now) - and so far folk seem to like it
megajolt has been around for a while now and is a little out of date, but it a proven product and the EDIS4 actually gives you a backup (ford designed it to run on its own in 'limp home mode' if the ECU ever failed)
Its possible to do megajolt for less £ than Nodiz, but you need to source the donor bits yourself - which means searching the local scrapyards for early 90's fords...
the new megajolt 2 will also not require an EDIS - but it could be ages before that's on the market (there other projects have the priority)
mtechmatt
posted on 12/6/14 at 05:28 PM Reply With Quote
We have just added the Megajolt Map import feature also which will spread the 10x10 map over the 16x16 map of the nodiz, so any MJ maps can now be easily used
V4 Engine Management System | Online Shop | Rolling Road Tuning | Motorsport Preparation | Engine Packages | Throttle Bodies
Check out what's happening in the workshop via our Facebook Page:
The Workshop
MEGASQUIRT ROLLING ROAD & BIKE CARB TUNING SPECIALISTS
www.mtechautomotive.co.uk
