Author: Subject: nodiz pro
mike2704
posted on 5/9/14 at 06:52 AM Reply With Quote
nodiz pro
Hi Has anyone used Nodiz pro ECU and have there been any problems thinking of using for my crossflow to zetec upgrade any information will be appreciated.
Thanks Mike
BaileyPerformance
posted on 5/9/14 at 09:14 AM Reply With Quote
We mapped one on a x flow, once we got it mapped it was fine but the wireless comms was rubbish, kept dropping out, real pain.
Not sure why the designers thought a wireless system was a good idea in a noisey environment like an engine bay.
But, to be fair, once mapped all was well!
mtechmatt
posted on 10/9/14 at 08:19 PM Reply With Quote
Dave,
A little tip I have told some mappers - use a USB extension cable and tape the bluetooth dongle to the unit for mapping
We made the system wireless so people could use the free android digital dash app
If the unit is inside the car the comms are usually very good, of not, as above just use an extension cable to have the bluetooth dongle as close as possible to the unit
Now I know you map them I'll add you to the mappers list on our website if thats OK?
Matt
V4 Engine Management System | Online Shop | Rolling Road Tuning | Motorsport Preparation | Engine Packages | Throttle Bodies
Check out what's happening in the workshop via our Facebook Page:
The Workshop
MEGASQUIRT ROLLING ROAD & BIKE CARB TUNING SPECIALISTS
www.mtechautomotive.co.uk
BaileyPerformance
posted on 11/9/14 at 09:48 AM Reply With Quote
Originally posted by mtechmatt
Dave,
Matt
Hi Matt,
Do you recommend a particular make of bluetooth dongle?
Maybe its worth adding USB in future versions - a couple of spare pins on the connector could be used for USB to save adding a mini connector on the case?
Adding me to your mappers list will be appreciated :-)
Cheers Dale.
www.baileyperformance.co.uk
www.facebook.com/baileyperformance
mtechmatt
posted on 11/9/14 at 02:56 PM Reply With Quote
Dale,
We supply a dongle with the units - usually works up to around 3 meters even next to the HT leads
USB is on the list next - we are changing the processor over to an ARM device which has USB built in so that will make things easier for those that want it - that being said right now we are focusing on our new ME442 ECU and ECOBOOST ecu
Matt
The Workshop
Alan G
posted on 26/9/14 at 01:32 AM Reply With Quote
I've used Nodiz with my 2.0 blacktop. Started up first whip of the key and has been running flawlessly ever since!
Would highly recommend using it and Matt is a great help if you have any problems along the way!
Al
Alan G
posted on 26/9/14 at 02:30 AM Reply With Quote
Forgot to mention that I used the function on the Nodiz EZ tune software to convert an old megajolt map I had to the Nodiz format.
No problems to report.
mtechmatt
posted on 6/11/14 at 12:15 PM Reply With Quote
Alan,
Thanks for the positive feedback - and glad you found the megajolt import to be helpful.
matt
The Workshop
