Author: Subject: NODIZ Pro with Terminated 'Clink and Go Looms' now only 299inc :)
mtechmatt
posted on 5/11/14 at 03:24 PM Reply With Quote
Chaps,
Some may be interested in this
NODIZ Ignition ECU with FULLY TERMINATED LOOM for Zetec 1.8/2.0
Sure a group buy can be arranged
Matt
V4 Engine Management System | Online Shop | Rolling Road Tuning | Motorsport Preparation | Engine Packages | Throttle Bodies
Check out what's happening in the workshop via our Facebook Page:
The Workshop
MEGASQUIRT ROLLING ROAD & BIKE CARB TUNING SPECIALISTS
www.mtechautomotive.co.uk
Ugg10
posted on 5/11/14 at 04:24 PM Reply With Quote
Interesting solution, quick questions -
I had a MJ Jnr on a Zetec in the past and that had a TPS connector, the loom shown on the link only has Crank and Coil (+ and -ve as well obviously), how does it sense load or does it have a MAP sensor built in?
[Edited on 5/11/14 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
mtechmatt
posted on 5/11/14 at 05:05 PM Reply With Quote
The loom pictured doesent have the 3 flying wires for the TPS/MAP sensor - normally it does.
Pics will be updated in due course
The Workshop
posted on 5/11/14 at 05:54 PM Reply With Quote
Sounds interesting. I was planning on injecting, but I have a perfectly good set of Weber 40's sat on a shelf gathering dust.
Do you have maps for a Zetec SE (Sigma)? Not fussed about the VCT as I'd likely be fitting aftermarket cams and disabling it.
It's Evolution Baby!
posted on 5/11/14 at 05:59 PM Reply With Quote
Looks interesting!
You may want to contact ChrisW and register as a trader (apologies if you're already in the process).
femster87
posted on 5/11/14 at 09:15 PM Reply With Quote
I think you should see me the 40's for a goooooooood price
mtechmatt
posted on 6/11/14 at 10:32 AM Reply With Quote
Yes we have maps for the sigma... if you were thinking about controlling the VVT properly our St170 VVt Controller also runs the SE/Sigma VVT
http://motorsport-electronics.co.uk/st170-vvt-controller.html
Matt
The Workshop
